VSC / VSC OFF Lights
Old 02-19-24, 06:02 PM
  #151
majerrahim
4th Gear
majerrahim's Avatar
hello everybody, new lexus owner, sc430 pebble edition, i have a question, i recently got cel light on and vsc also on, plus that other light cant remember, ran obd scanner and got code p0031 h02 sensor heated control circuit low bank 1 sensor 1, any idea how to proceed? what could be causing this, is it the actual sensor or could it be something else?if its the sensor does any one knows if its passenger or driver and where its located? and if you have a part number, i tried for days on the web to search but no luck, thanks in advance, I love the car
Old 02-20-24, 08:18 PM
  #152
Ave185
5th Gear
Ave185's Avatar
I have this problem often. My mechanic suggested I go to You Tube and find a video to see how to reset. He said it is not difficult. With that encouragement, I searched and found this info. I am unable to post the link to the video, but the title caption is:
Re-calibrate reset the VSC TRAC on Lexus SC430
Following the replacement of the O2 sensors on my wife's Lexus SC430, the shop failed to reset the VSC TRAC lights. I was able to DIY the reset using a paper clip. First, make sure the vehicle is on a level surface and the front wheels are facing straight forward. With the keys NOT in the ignition set the paper clip to the jump the appropriate pins. Then insert the key and turn the ignition to ON but do not actually start the motor. The VSC lights will flash consistently, meaning the system is being reset. You only need to see the blinking for a few seconds. Now turn the ignition off and remove the keys. Next remove the paper clip thus disconnecting the jumper. Start the car and the lights should turn off.”
Old 02-21-24, 05:37 AM
  #153
Bgw70
Bgw70's Avatar
this might be the video you referenced.
weird that you couldn’t post a link
jump pins 4&14 on the OBDII connector
Old 02-21-24, 06:54 AM
  #154
Ave185
5th Gear
Ave185's Avatar
https://www.youtube.com/watch?v=CV0_5Tau6TY
Agreed. Thanks for posting.
Old 06-01-24, 11:38 AM
  #155
markfx
markfx's Avatar
Yes, the jumper hack still works as of 6-1-24. Thanks!
Old 06-15-24, 12:40 PM
  #156
Cbaker9
1st Gear
Cbaker9's Avatar
Originally Posted by CBG
How can they do a "inspection" without taking the wheels off to check brakes? Try taking your Lexus to a Toyota dealer to "plug in" because they will probably charge alot less. Though I don't know if they have the codes for a Lexus. I say take it to Toyota because I recently bought new rims and tires and tire pressure monitor sensors(TPMS). My Lexus dealer wanted $350-$400 to program the new TPMS to my car. I took it to a local Toyota dealer and they did it for $95 BIG DIFFERENCE.
Good Luck
In Georgia they just do an emissions inspection.
redliner8
01-04-23 01:39 PM
akafixture
02-13-20 05:28 PM
scotchbro
01-24-15 12:11 PM
Sublime69
11-21-12 03:30 PM
sc430blue
01-26-05 08:42 PM
Quick Reply: VSC / VSC OFF Lights
