Rims question
Rims question
Soo..
I found a set of rims that I really like for my sc430 (FINALLY..) The bolt pattern is 5 x 4.5, which I assume is the same as 5 x 114; basically it'll fit the SC. However, the owner of the rims is telling me that the offset is +38.
Does anyone know what offset +38 means? I just really want a sexy rear lip..
Thanks!
Thanks!
Soo..
Thanks!
Thanks!
Stock offset is +45 just means the new wheels will come out a little more towards the fender.
If you want a *sexy lip you can go much more aggressive offsets +38 would be very conservative.
Whats the wheel size and width?
Cycle Savant
The offset needs to be wide enough to clear the brake caliper.
For the stock wheels, it's 18" in diameter, with an 8" wheel width, and a 42+ offset (if I remember correctly).
If by chance your wheel is the same diameter and width of the stock wheel (18"x8"), your new wheels will be 4mm shorter than stock (42mm minus 38mm). Not that big of a difference, but the wheelbase will be a little narrower (8mm to be exact, when you count both sides). The difference can be aesthetically corrected with spacers, but if it rides well, then you really don't need it.
The owner of the rims said the specs are:
20 x 7.5, +38....5 x 114.3
7.5...isn't that like, not as wide as the sc stockies?
here's a pic of the rims.
http://i239.photobucket.com/albums/f...g?t=1229723270
