When to replace timing belt?
I'm pretty sure that is incorrect. The 4.3 V8 in the LS, SC and GS are interference engines, so big $$$$ if the belt were to break. All V8's with VVT-i are interference. It is confusing, as the orginal 4.0 V8 in the old LS400 was non-interference. That changed when the variable valve timing was introduced.
I would change it at 90k for peace of mind.
I will place my bet with Bergstrom Lexus in Appleton WI. If anyone else gets a different answer from a dealer let me know I put on 30 k a year, have 76 k on it already and plan on waiting till 110 or so. The dealer knew exactly what i meant when I said interference
http://www.gates.com/part_locator/in...cation_id=3598
So, if you delay changing the timing belt and....
1. It is a non-interference engine: You get to DELAY but not avoid the cost of a timing belt by about a year or two. You save (assuming a generous interest rate of 10% X $1400 installed. So you save $140 by taking the risk.
2. It is an interference engine and you have the timing belt break. You get to pay for a major engine rebuild and that probably costs a "little bit" more than $1400
I don't think it is a risk/return proposition that makes a lot of sense for delaying the replacement. I intentionally had mine done a little EARLY. I've had a timing belt break in a mustang. It was NOT an interference engine and yes it merely stopped. However, the time and aggravation of getting towed and the danger of being stuck on the road encouraged me to avoid it ever happening again. Hence, I had my SC430's timing belt swapped out preemptively.
According to Gates.com, all 430 are interference engine.
I would assume like anything from the Lexus dealership, we'd get screwed over with the pricing. Anyone ever get it done at a Toyota dealership instead? What was the price there vs at Lexus?
I believe the cost at Lexus averages around $1400.00 and Toyota does it for around $800.00. I'm sure this may vary at different dealers but this is what I have heard... This would be the timing belt, tensioner, waterpump and labor.
UofOMom
11-22-12 12:25 PM
