I was wondering if anyone has experienced problems starting the car up again right after turning the motor off. It seem like when the motor is still warm and i try to start it up, sometimes it will give me issues. It will eventually start after a few tries. Any input would be greatly appreciated!
I actually don't have that problem. Usually the car starts right away once it has been driven. I think you may have a battery issue from the details you provided on the issue. Do you know if the battery was replaced when you bought the car?
i bought it used about 4 months ago and the seller said he just replaced the battery. The engine cranks but just wont start until i try multiple times. i have only noticed this when the engine is warm or hot.
check your fule pump or spark plugs
I had the same problem and the dealer said it either fule pumb or plugs. Finally they end up changing the plugs (onley one was bad but i chnged it all)
good luck
