I have to use Run Flats, which are best
I have read dozens of posts here on the many advantages of using a non run flat tire. I agree that they will ride better and give better road handling. But our 2004 SC430 is my wife's car, I have a 2010 RX (great SUV by the way!). My wife doesn't ever want to be out driving without run flat tires. And as I'm out of town on business at times, I would feel better that she did have them. She never goes more that 50 miles from the Lexus dealer in the SC anyway. The SC has 20,00 miles and the tires need replacement now.
So having said that, which run flat will give the best ride. Handing is not a big issue as my wife never drives over 70 mph and doesn't take corners that fast. We do have light snow here in norther VA, but on those days she just stays home.
Any help on brand and model would be very helpful. BTW, this is my first post here but I've found a lot of good info on these pages, thanks!
Louis
Louis
in your post, you kind of set yourself up for thinking that your wife would be fine NOT going with run flats....50 miles from the dealers, etc etc.
I drove for three and a half years with no spare no run flats and many on club lexus do as well. Lexus has excellent roadside assistance!!!
Having said that not only do you severely compromise road noise and ride quality, you more than double your price. Example: Set of four Dunlop Direzzo tires mounted and balanced for under $800. Set of Dunlop Sport SP Run Flats =$1600.
I would seriously reconsider...but I understand about the safety. My SC was only driven 5k miles in that time and yours is a daily driver.
Look at what the ratings are from end users on the run flats from www.tires.com
Looks like the Dunlop at $350/each are your best rated, plus discount tire gives you lifetime balance/rotate for free and free air check.
http://www.discounttire.com/dtcs/tog...&fcb=&sw=false
BTW, welcome to CL, Louis48.
![Wink](https://www.clublexus.com/forums/images/icons/icon12.gif)
I bought two cans of fix a flat (Yes I know about the TPM Sensors) a small but good quality air pump and took my wife out to the garage. I let the air out of a rear tire, showed her the warning on the dash, showed her how to either use the Fix a Flat or hook up the pump and inflate the tire. I then let the air back out of the tire and told her it was her turn. She had no problem inflating the tire and putting everything away. We went back inside and she felt comfortable about being able to handle a flat if she picked up a nail.
At the same time I showed her the battery booster (From Harbor Freight) for jump starts that is in the garage and explained that it was red on red and black on black. This information was used recently as she went and jumpstarted my daughters car with it when my daughter had left her lights on at the mall.
Don't tell them how to do something, show them and they will understand.
I put the Pirelli P-Zero M+S Run Flats on and they've been quite good, much better than the previous tires. After about 14kmiles they started being a bit noisy though. They are fairly cheap too from Discount Tires.
Almost all of the Fix-A-Flat type products remain liquid. As you drive the centrifugal force will spread them around the tire and normal balance is resumed. Once you get the tire to a repair shop, if you tell them you used Fix-A-Flat they will blow the tire up to about 45 lbs of pressure, remove the tire valve core and the remaining fix a flat will discharge out through the valve stem. They might have to do this twice to get it all out. This isn't a problem if they dismount the tire and put a proper patch on the inner wall instead of a plug through the nail hole. If they are using a patch they just wipe the tire out with a cloth and the tire is back to normal. I have had them wipe the TPM sensor off with denatured Alcohol and have never had a problem with those either. I used to have AAA but twice we waited almost 2 hours in rush hour traffic for their service truck. Fix-A-Flat and an air pump and we are on our way in under 10 minutes.
I have gotten three nails in my tires over the years. As soon as the pressure lights came on I stopped and pumped them back up. { I have a portable pump** Rode on to the next tire service shop and got them fixed.
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
I want to thank all of you for the replies and help. I might ask my wife if I could train her on the use of a pump and a can of Fix-it compound. But if not, the two tire recommendations will help me pick a new set of tires. I really like this Forum, and thanks for taking the time to share your thoughts with me. Louis
We both considered the Run flats dangerous because because on the road they picked up on any and every rut they found and wanted to take off on their own.
The last blow out I had was on my ES300. I had changed wheels and had not yet gotten a spare. We were in the middle of nowhere in Limerock,CT and it worked out fine (on July 4th). We were towed to a local shop near the track. they picked up a tire and we were back on our way in couple of hours. I'm not sure how the Run Flats work with a blow out.
My new Boxster also has no Run Flats and no spare. Porsche supplied the flat-fix as well as a compresor.
