Headlamp went out :(
Ok so I'm driving along the other night and my left headlamp flickerd out this headlamp has been replaced a couple months ago does any one know if this is common. by the way its 2007 sc430. I also wiggled the wires behind the headlamp to see if it was loose connection no luck. Any help would be appreciated
I had a similar experience a while back. Turned out to be a small crack in the little black box that holds the ballast. Water got in. Dryed it up, sealed the crack with caulk and no problem since.
+1 on using the dealer as much as possible! he he I wore them out with my platinum warranty...God help them if I had bought the car NEW on top of that! They would have been better off just giving me a new car.
whoever put the bulb in might not have used the right intensity...I have seen the wrong intensity bulbs burn ballasts before. somewhat rare, but does happen, especially with cheap bulbs
+1, good tip on the bulb grease, most people never use it and regret it when they have to do a replacement
zachk86
08-13-12 12:27 PM
