Replacing front sidemarker bulb - 2002 430
You can access the front and rear sidemarker bulbs going through the wheel well.
- Front: The front has several screws in the wheel well, but once they're off, reaching in to get the bulb is fairly easy. Make sure you turn your steering wheel all the way to the one side so you have room.
- Rear: Remove wheel. I believe the rear wheel well has 3 screws you need to take off. Then reach your hand in and feel around for it. The rear is tighter than the front, but it can be done. I
Good luck!
Good luck!
DJHydrogen (02-18-20)
TAMR_GUS98
09-05-18 04:48 PM
