SC430 brakes same as 2GS brakes?
Old 11-12-09, 01:53 PM
JeffTsai
JeffTsai's Avatar
Default SC430 brakes same as 2GS brakes?
Ok, I have a problem. I just bought some brakes that were for a Supra and the front bolts up perfectly on my 2GS front. However the rear is different from the Supra brakes. The company makes brackets that are application specific for the IS300 and SC430(same part number) but they don't list compatibility for the GS. I even went on Autozone website and looked up both the SC and GS and they both share the same caliper and rotor part numbers.
Soo....in short. My question is if the SC430 and 2GS share the same rear brake setup from the factory?
I know some of you guys here have had both cars before and might know. Thanks in advance!
Old 11-12-09, 03:38 PM
loveslexus
The Dog Whisperer
loveslexus's Avatar
Why go with the rear supra calipers? Any real diff. then the oem GS ones?
Old 11-12-09, 03:48 PM
loveslexus
The Dog Whisperer
loveslexus's Avatar
...and who's brake lines do you use? Front and rear Supra ones or Lexus ones?
Old 11-12-09, 05:08 PM
talwang
talwang's Avatar
They are the same.
I've also checked the oem catalog and it shows UZS161 has exactly the same rear brake setup as UZZ40.
Old 11-12-09, 05:47 PM
JeffTsai
JeffTsai's Avatar
EDIT: Talwang I just saw your post. Thanks for confirming for me. I'll go order the new brackets tomorrow. Thanks again!
I'm not using the OEM Supra TT brakes. I'm using these brakes. The brackets were for a Supra, not for a GS. Hence why I'm wondering if the SC and GS brakes are the same. They make brackets for the IS and SC, but not for the GS. I have a gut feeling they're all the same bracket and someone at the company just didn't test the bracket for fitment on the GS.
Old 11-12-09, 06:40 PM
talwang
talwang's Avatar
No problem. I also post the pics of both lists, so you can double confirm.
I love your new BBK setup. $$$$$$$
I thought Brembo only makes the rear GT BBK for the LS430 and IS250/350.
Hope everything works out nicely for you.
416tt
04-15-14 11:42 AM
waijai
07-07-11 06:29 AM
Blizzy
Suspension and Brakes
07-23-07 05:25 PM
PM Supra
32
02-21-06 03:39 PM
Boostshakalaka
01-16-04 12:18 AM
Quick Reply: SC430 brakes same as 2GS brakes?
