Which would you choose?
#31
You also mentioned the timing belt being replaced...was it the timing belt or the accessory belt? Seems low mileage for the timing belt. There were problems with the OEM accessory belt...Lexus issued a TSIB (Technical Service Information Bulletins) on them by car model VIN.
#33
Brought my car into Ray Catena Lexus for a well check. They inspected the car for safety issues, looked at the motor mounts, and all checked out ok. The service rep said that they arent going to look for problems beyond safety issues but if I could mention something specifically they would address it.
Also just ordered a couple of blank keys from ebay so that I could have 2 spares.
Best,
Jack
Best,
Jack
#34
Lexus keys have transponders built into them. The theft deterrent immobilization system only recognizes a total of four keys for the car. Those are typically two masters, one valet and one wallet key. Adding "new" keys you must programmatically delete existing keys from the ECU, or take the keys apart carefully and move the transponder into the newly cut key. There are a few other threads regarding programming a key.
rclab1
12-17-11 12:06 PM
