Dynaudio 240MK2 2 ways speaker
I have a pair of dynaudio 240 MK2 2 ways speaker, these system with crossover network. And I going to install these speaker system. The problem is the ML amp drive the stock driver (6*9 woofer and squawker and tweeter) with the electronic crossover which buildin in ML component amp? Is it correct? If not, but I can not see the crossover network between the woofer and tweeter.
Anyone can tell the correct ? And how to wiring with two ways speaker system. many thanks.
more importantly than getting the crossover setup correctly is to make sure the impedance of the speakers are the same..
If your new 2 way setup is 8Ohm then you're good to go.
Utilize the crossover in the ML system and just swap out the stock woofer for your woofer and the stock tweeter for your tweeter.
Contrary to what you think, the crossover in the ML amp is only a 2 way and not a 3 way. The same output goes to the tweeter and squaker. And by not altering the wiring of the ML system you will still hear the NAV output to the speakers.
