SC430 Strut Issue/Spring Install
Last weekend I tried installing some Tein springs thinking it would be no big deal as I've done springs before. Upon disassembly, I came across something wierd that stopped me in my tracks. I started on the passenger front, removed strut/spring assembly, then removed tophat. When I went to install the new spring, I couldn't get the strut to come up far enough for me to re-install the top hat.
I had spring compressors on both side of the spring, both maxxed out pretty much, and still the strut wouldn't come up far enough. On the last set I did (subaru), I could just pull up on the strut piston and it would stay up, allowing me to assemble easily with no need for spring compressors. I tried pulling up on the piston, which gave me about 1.5-2" of height, but if I let go it would retract immediately. Anyways after a couple hours and some internet searching, I gave up and tried to put the stock spring back on. This ended up being even harder because the stock spring is taller than the Tein one.
What I ended up doing was using a crescent wrench to pry the strut piston up, using the spring as a leverage point, so that someone else could re-attach the top hat for me. It was pretty difficult but I got it back together eventually.
What I'd like to know is if anyone else has seen a strut act like this, and if I were to attempt it again, what can I do to make it easier. I'm considering just taking it to the dealership and paying them 135/hr to do it.
Thanks
Thanks
I did have the spring compressed while disassembling, that part was easy. I also was using air tools to take the lock nut off. It wasn't the tools that were the issue, it was the strut itself. Logic would have me believe that a strut would naturally push outwards to dampen any forces, but this one 'sucked in' instead. So weird, maybe the strut is blown or something?
Thanks for the response though, any input is appreciated.
Yeah the absorber rod, or piston as I called it earlier. I actually tried putting the top hat on and pulling it out like you suggest, but as soon as I took it off to put the spring in, it'd retract before I had a chance to get it all together haha. I seriously thought it was messing with me on purpose.....I threw a wrench and lost it in the grass lol
haha.. stupid me, it would go back in once the top piece is removed.
I honestly didn't see my mechanic had problem with the piston part as I was right beside him the whole time while he was installing them.
He told me that removing the trunk interior tirm was more difficult than springs.
You can wait for our moderator Pearlpower to chime in, he can definitely help you.
Well thanks anyways, if anything I just want to find out if I'm stupid or not lol. I may just give in and take it to a mechanic, but it'd be nice to know how to do it myself, and perhaps this thread could be a valuable resource for anyone down the road that wants to do the springs.
Ur strut may be blown. a strut is suppossed to be extended (not compressed) when there is no load. So the strut piston should naturally go all the way up on its own, never down.
Im going to be doing my springs install tomorrow...will be using GS400 Bilstein in the front, with S tech teins. Ill let you know how it goes.
By the way, the Bilstein struts I got are super strong, I cant event compress them myself (as oppossed to OEM struts which give in with some pressure). And they are all the way out.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I'm going to go look for that wrench now, good point about the lawnmower
COil overs are always better but the price difference is huge.
Even with me getting the 2 front bilstein shocks my total was about $450
Coil overs is like 4 times this!
But if you want to spend the money, by all means coil overs are always the best route.
BTW the rear shocks were a pain in the ***! You have to take so many htings appart its not even funny....the whole trunk, the wheel liner, stabilizer bar, lower control arm bolt, etc. Total pain in the butt.
