Pros and cons of driving in ECT Power mode
Old 04-15-10, 12:19 PM
IStoSC
IStoSC's Avatar
Default Pros and cons of driving in ECT Power mode
I wanted to know the pros and cons of driving in this setting thanks in advance
Old 04-15-10, 01:30 PM
da-bizket
da-bizket's Avatar
Pros:
Less torque converter slippage = better gas mileage.
Cons:
None
Old 04-15-10, 01:58 PM
IStoSC
IStoSC's Avatar
^Then my car shall forever stay in this mode...
Old 04-15-10, 02:41 PM
jimmer!
jimmer!'s Avatar
the 430 manual warns about decreased gas mileage in the PWR mode.
I was surprised to find, not only performance improvements, but better gas mileage.
what's up wid dat?
and is there a method to optimize the programmed PWR performance?
the car's chip monitors driving habits.
are there a specific ways to trick the PWR mode into even better performance?
Old 04-16-10, 07:23 PM
Tensi
Tensi's Avatar
What?? MPG increased?? No way!
Old 04-17-10, 02:22 AM
carbuff
carbuff's Avatar
I conducted a test checking MPG in each mode.
After four gasoline fill-ups in each mode, the MPG was the same; no increase or decrease in MPG.
For the entire life of my SC, I have averaged 15MPG from the first fill-up to the present time driving mostly stop and go on city streets with very little freeway driving.
Because I prefer having the extra pickup power, I keep the PWR mode on at all times.
Old 04-17-10, 08:01 AM
jimmer!
jimmer!'s Avatar
I was getting an average 21 mpg in standard mode.
PWR mode now yields an average 22-24 mpg using trip monitor.
as for rating mpg using the 'old method' how would you accurately
gauge the precise distance v. number of gallons used?
mileage yes, but how do you accurately apply that to actual gallons?
please explain.
Old 04-17-10, 10:49 AM
Tensi
Tensi's Avatar
very interesting. Thanks guys.
Old 04-17-10, 09:18 PM
nkx1
nkx1's Avatar
please explain.
I think you're asking how to calculate mpg? If so, reset your trip meter next time you get gas. The next time you get gas after that, simply divide the miles on your trip meter by the number of gallons it took to fill your tank..
For instance:
-You fill your tank with 15 gallons (make sure your tank is full)
-Your trip meter says you have traveled 250 miles
The equation would be 250/15 = 16.66 miles per gallon
Old 04-18-10, 10:34 AM
Harold57
Harold57's Avatar
The tricky part is filling your tank to the same level every time, unless you fill it to the point where you can actually see the top of the fuel.
Old 04-19-10, 10:03 AM
Tensi
Tensi's Avatar
You are making it a ton more difficult.
Fill it up. Restart trip odometer. Next time you fill to top, divide miles driven on odometer by gallons filled. DONE.
Old 04-19-10, 12:32 PM
jimmer!
jimmer!'s Avatar
now that makes sense.
I'll try it, but I'd hate to have my 24.4 mpg bubble burst!
Drbrdb (09-22-19)
Old 04-19-10, 04:39 PM
iolmaster
iolmaster's Avatar
I average 24.5 and I have confirmed that with the old fashioned way. You may not have your bubble burst. Now, mine is average. Not just city. I do a fair amount of highway driving.
Old 04-20-10, 07:08 PM
Harold57
Harold57's Avatar
The problem with that method is that it doesn't give you the true gas mileage. It only tells you what the mpg was for the amount that you put in the tank. I've noticed that on a typical fillup on my SC430 that I can add as much as 1 1/2 gallons after the pump initially stops. That leaves a lot of room for error, something like plus or minus 7%.
Old 04-20-10, 08:43 PM
Roofless
Roofless's Avatar
Eggs Akley!
Quick Reply: Pros and cons of driving in ECT Power mode
