Taillight assembly removal - help...
Hi Everyone - first post here.
I've read where to remove the taillight assemble one should first remove the hex bolt under the plastic plug - done that.
And then "slide the unit towards me." Huh? Ain't no room to slide nuttin'! It butts up against the top of the bumper assembly.
Can anyone be a bit more descriptive?
Thanks!
Erinaldi
Thanks!
Erinaldi
The instruction are correct. I am attaching the printed instructions. There are two sets of guides. Depending on how long they been in place they're going to be tight. A TAPED flathead screwdriver is suggested. Just a nudging and pulling STRAIGHT back works them loose and out of their mounts.
^ Bob's right...they should just slide out (with a good but not too hard pull or use a covered flathead). My 05 were like pulling a pie out of the oven they were so easy.
Like a dork, I waxed them and surrounding areas before I removed too Little lube didn't hurt anyone you know?
