I found my annoying squeak near the rear window
Old 02-16-20, 08:50 AM
  #46
qswo
qswo's Avatar
thank you that was it
Old 08-23-20, 10:26 AM
  #47
Cinc04
Cinc04's Avatar
Bon, I don't know if you are still monitoring the site (2010), but I just completed your "fix" for the squeak at the rear window and it worked perfectly. I also did the dressing of some of the rear seals in the area as good measure. Thank you for helping me solve this annoying issue.
Old 05-30-22, 07:53 AM
  #48
fishinmagi
fishinmagi's Avatar
I also solved my problem using the solutions in this thread. FYI I had to adjust the bump stop about 2.5 turns counterclockwise.
On a similar note, I had squeaks coming from what sounded like the front passenger side wheel. there are 4 bump stops under the hood that can be adjusted similarly to eliminate the squeaking
AJL0365
09-12-12 07:05 AM
SnoopyBQ
10-25-11 01:22 PM
ISking
01-03-10 06:39 PM
pmd
02-25-03 09:47 AM
Quick Reply: I found my annoying squeak near the rear window
