HELP! once i hit highway speed, VSC, VSC OFF and ABS light come on
any help? all 3 lights come on when i hit high speed. then after i stop they go off. i just noticed its not at high speed anymore and today it was at 35+ mph
any suggestions?
joey
any suggestions?
joey
This could be as simple as some debris on the speed sensor so you'll need to inspect them. Or it could be a lot more complicated and that means a scan tool for error codes. Do you have access to scan tool for error codes?
I attached an exploded brake system diagram, which includes the speed sensors, in another thread this morning. Pages 5 and 6 of that PDF have the speed senors. Here's the thread https://www.clublexus.com/forums/sc-...-question.html
Well that's going to be determined by any error codes that come up...e.g. damage sensor(s), dirty sensor, a bad cable or connector or any number of things.... there are about 20 error codes associated with VSC/ABS systems.
jrmyrnsm
GX - 1st Gen (2003-2009)
06-29-19 05:03 PM
Globalinx
03-04-14 01:17 PM
