Interior light help.
I replaced my cabin filter yesterday and just found out my glove box light is not working. Bulb seems to be ok, checked it with my ohmeter. I checked the voltage across the connector, it is only giving me 0.18 volts when the switch is on...what's up with that? Should be 12V.
Needless to say was disappointed, thought was going to upgrade to LED's.
I suppose the logic is it needs to be dark enough to need your headlights on before you'll need the glove box lamp to light when the glove box door is opened......
