Re-torque drive shaft flange bolts?
Old 06-08-10, 02:08 PM
ual320jet
ual320jet's Avatar
Default Re-torque drive shaft flange bolts?
Does anyone now the torque for this? I am doing my 50,000 mile service and have not done this in the past. Is it needed for the SC430? If you have socket size, torque setting, pics, please post. Thank you!
Old 06-08-10, 02:23 PM
VVTiBob
VVTiBob's Avatar
Here's the overhaul PDF for a 2002 SC430 it contains the torque specifications and some other important notes...
File Type: pdf
Old 06-08-10, 02:57 PM
ual320jet
ual320jet's Avatar
Thank you VVTiBob! I will get on it today.
Old 06-08-10, 08:30 PM
scdroptop
scdroptop's Avatar
I'd recommend. I had some sqeaking one time in my 02 because of this and they did it for me because apparently it hadn't been done on the other regular service intervals. it fixed that problem that time. Not sure what other issues this could cause if you ignore.
Old 06-08-10, 09:24 PM
ual320jet
ual320jet's Avatar
Just quickly looked at the pdf file. If I am correct, 6 bolts at 58 ft lbf. Has anyone done this? Can I fit a torque wrench in and re-torque?
Old 06-09-10, 04:25 AM
Poqman
Poqman's Avatar
When you do this, please let us hear if the bolts were still set at the recommended torque or had they loosened. I have always questioned the necessity of doing this maintenance. Your results could change my mind. Thanks.
Old 06-09-10, 09:32 PM
BNR34
BNR34's Avatar
+1
Always thought is a dealer scam.
Old 06-11-10, 11:21 PM
ual320jet
ual320jet's Avatar
I can tell you they are 17mm. I need an adapter for my torque wrench. It is going to be a tight fit. Not sure it is worth it unless you hear a noise shifting.
Old 03-26-17, 08:07 AM
jspringato
jspringato's Avatar
Has anyone done this? Pictures? I'm going to be towing around 1,100 pounds, so I need to make sure this gets done.
Old 09-22-17, 09:03 AM
zajacjoe
zajacjoe's Avatar
I just did this service. Some tips. Of course block the car and use jack stands!
There are 6 bolts at the engine connection and 6 bolts at the differential connection. 17mm
socket.
You can only get the torque wrench on 1 bolt at a time then you have to turn the flange to access the next bolt.
Mark the bolt so you know which ones were done. I used white out
To do this, jack up one of the rear tires off the ground so you can turn the flange with the engine in neutral.
Position the flange so you can access the bolt then put the car back in park to lock the flange from rotating when torquing
BTW all my bolts were tight! None moved when re-torquing
Jabberwock (09-22-17)
TXFM
03-25-15 07:16 PM
dwlink
RX - 3rd Gen (2010-2015)
10-24-13 06:45 PM
mcfly
01-19-06 09:12 AM
STR8-UP-G
Maintenance
07-07-05 12:51 PM
davidfarmer
01-28-03 10:44 PM
Quick Reply: Re-torque drive shaft flange bolts?
