Stereo project begins...
Old 08-09-10, 06:31 PM
  #31
Peter_Klim
Peter_Klim's Avatar
Originally Posted by jimmer!
dumb question, but is there a way to simply replace the current amp (in the trunk) with your new one? I understand, the OEM amp is connected to lots of things not audio, but considering the lack of usable space, swapping the new for the old amp would be the way to go, if at all possible.
that said, I bet you know what you're doing, peter.
so, what are the problems with 'swapping' rather than 'adding' the amps?
PS - I don't think the stock amp is being used. I glanced at the schematic and didn't recall seeing a need to use it (at least ot for what I need my system to do)
Old 08-09-10, 06:39 PM
  #32
Peter_Klim
Peter_Klim's Avatar
Originally Posted by t119
Sorry this took so long. I've been moving and things have been pretty hectic haha.
But the installation is almost done. I still have to finish putting in a few things such as a more powerful amp for my sub and a satellite radio hook up.
Once my SC was in the shop and half way through installation, the shop realize that in order to get a working top screen (where our stock nav is), I needed a different unit than the JVC. I ended up getting a clarion nx700 double din unit. The reason being because it is capable of playing on two different screens at once (i.e. DVD up top screen and navigation on bottom screen).
I am planning on taking the car in again when all of my parts are in, which should be sometime this week. Once I have everything in, I will be sure to have a write up on my system.
BTW, I have a bunch of mark levinson parts sitting around that are ready to be shipped out to a new home
Clarion makes some pretty good head units. Sucks you have to wait longer to get the system completed, but in the end it'll be worht the wait getting everything the way you wanted.
My head unit isn't as flashy, but what i do like about it is what you were saying, which is to have at least one know to control the volume. As you can see, mine has one HUGE ****. The center of it is is a pushbutton that makes it easy to scrolll through the other settings (like bass/ treble). I would always want a **** or at least some buttons in a car stereo for ergonomic control...although it's not as nice looking as the Clarion!
So when yours is finished, you'll be able to push a button so that the video signals going to the top screen and button screen will flip?
Old 08-09-10, 06:44 PM
  #33
Peter_Klim
Peter_Klim's Avatar
. To get the wood pannel to go up and down, I had a button installed in the ash try along with a video bypass button.
They need to use parts from the stock head unit to get the orignal button to open and close the door. Oh wait, but you are/have sold the stock radio. OK, nevermind Gald a solution was found!
Old 08-12-10, 05:54 AM
  #34
bobcat1
bobcat1's Avatar
Looks great so far-- AS you know, I have the same set up in my back seat-- I wish I lived closer to you, I would love to see (and hear) the finished product! Do you know what the max depth is for the rear side speakers? I'm thinking of matching / upgrading to my DCG's I put in the front.
Old 08-12-10, 09:49 AM
  #35
justinbig8
justinbig8's Avatar
Originally Posted by Peter_Klim
Then you're only a few miles away from me. Stop by and we can hit home depot to get the MDF board and I'll trace it for you. If you don't have a roto-zip we can cut it at my place.
Sounds good. I'll PM you my phone number and we can set up some time to meet this weekend. The closest Home Depot to me is on 17th and Wilson in Costa Mesa
Old 08-19-10, 07:10 AM
  #36
dracip
dracip's Avatar
They had to use part of the stock head unit.
Interesting info, Peter Klim
I think they must have kept a module/circuit board (with the radio connectors) to keep the data/digital signal flowing through TX wires. If we look at this diagram (thanks GammaLex ) :
https://www.clublexus.com/forums/sc-...-its-here.html
we can see that the radio (p. 321) is part of the navi system with 3 connections : ATX (to the navi screen), TXS (to the combination meter, which include speedometer info, p.320), and TX (to the amp, and ultimately the navi ecu, p.322). So the ML amp must also stay connected and powered on too to keep navi functionality (but the ML amp could be bypassed anyway, or LOCs can be used between the ML amp and an aftermarket amp).
Do you think your installer could tell you what they kept? If it involved lot of unsoldering inside the radio or just unscrewing a board? And how this part is always powered on? This would be very pertinent info.
Thanks!
Denis
Old 08-20-10, 09:27 AM
  #37
Alterious
Alterious's Avatar
Thanks!
Denis
i asked about the same thing
Old 08-20-10, 07:03 PM
  #38
dracip
dracip's Avatar
here?
Originally Posted by Alterious
what part would that be?
I meant no disrespect, I just did a little research to maybe narrow down the search on this part, and maybe I'm completely off track. But it seems we're both (and some other members too) eager to know how it works, don't we? And maybe it's easier to do than re-locate the HU somewhere in the car or performing surgery in the dash electronics.
Nice SC BTW
Old 01-01-11, 08:45 PM
  #39
Pnuge88
Pnuge88's Avatar
Remote turn on wire anyone? I dont see anyy gray wire at all in the main sc430 speaker install thread. I need help!
Old 01-02-11, 05:34 AM
  #40
tfeni52355
tfeni52355's Avatar
mIStaboi,
I did the entire upgrade as ZGone described just with different components. I have the entire trunk buttoned up so getting to the amp isn't going to happen unless it's for repair.
Here's my recommendation: Take a digital electronics meter, set it to DC. Connect the black meter lead to the chassis ground (any metal in trunk) and use the other (red) lead to search for a 12VDC signal at the amp. When you find it turn the ML HU off and see if the 12VDC goes to 0VDC. If it does you have a switching - amp turn on signal. Doesn't matter if it's gray. What matters is it turns on/off with the HU. Since it's a signal level line there is no power drain (almost none) on it so the chances of overloading anything are 'nil.
Good Luck!
Old 01-02-11, 06:45 AM
  #41
Pnuge88
Pnuge88's Avatar
I used a digital meter but maybe i will try it again. Thanks for the reply!!
SrWilliams
07-29-14 06:48 AM
pandaboyx
IS - 1st Gen (2001-2005)
09-16-12 01:45 PM
Red Bully
09-28-09 03:41 PM
sck_GS300
09-17-08 09:08 AM
mitsuguy
08-25-06 08:23 AM
Quick Reply: Stereo project begins...
