Seat Memory buttons stopped working?!
Old 01-27-17, 08:33 AM
  #46
Harold57
Harold57's Avatar
It may be a bad switch/button or the cable may be disconnected. Do either of the driver side buttons work? (My assumption is that like the SC430, your RX450 has 2 seat buttons.)
Old 01-29-17, 12:30 PM
  #47
DshngDaryl
DshngDaryl's Avatar
1. Move the seat forward until you hear a beep.
2. Move the seat all the way back.
3. Move the seatback angle switch forward until you hear a beep
4. Move the seat back angle switch all the way reclined.
5. Set the memory now.
This worked for me when I first bought my car. Recently when I disconnected my battery, moving my seat to the limits didn't do anything, no beeps.
It just dawned on me today, THIS IS PROBABLY A SEQUENCE PROCEDURE, it has to be done in sequence.
I am going to try it, as written, when I go out to my car later today and see if it resolves my problem.
Old 01-30-17, 03:30 AM
  #48
amitmunjal
amitmunjal's Avatar
My (2012) R450h has 3 Setting buttons (1,2,3) in addition to the SET button. (SPORTS LUXURY).
The passenger side SET and 3 settings work fine. The Driver side setting buttons are dead.
The car seat and steering do adjust to the position when I sit in the car.
May it's a late model issue. Any one experienced this.
ALSO is followed the procedure. NO Impact. I do not get any beeps.
Old 01-30-17, 08:33 AM
  #49
DshngDaryl
DshngDaryl's Avatar
So I followed the sequence and still didn't get any beeps, but when I programmed my seats they "took." The only thing I did different was have the engine on and the door open when I was moving them and when I was programming the seats.
Old 01-30-17, 10:36 AM
  #50
Bgw70
Bgw70's Avatar
sir, try asking your questions in the RX450 section...I bet you would find an answer.
you can stay here but we discuss the SC430.
Here is the RX450
https://www.clublexus.com/forums/rx-...2010-2015-212/
Old 01-30-17, 11:17 AM
  #51
Coleroad
Coleroad's Avatar
Here is the RX450
that cold wet weekend get you all fired up today. Lol a quick 5 thread run.
Old 01-30-17, 12:19 PM
  #52
Bgw70
Bgw70's Avatar
LoL, yea, I was stuck riding/driving in a car all day. Was up at Warner Robins, Ga for work, now back in slightly warmer and Sunny Florida!
Old 03-25-17, 12:32 PM
  #53
alex2016g
alex2016g's Avatar
Originally Posted by JohnnyCake
Make sure you are in park with ignition ON. Assuming you are....
Can confirm this worked on my 2004 SC. Thank you so much, second time it happened to me and last time had to take it to the dealer, save me some $
Old 11-01-18, 07:42 PM
  #54
SigmaBlue
SigmaBlue's Avatar
Default I need a good warranty
Originally Posted by willabeest
hello
new to the forum
2006 430 sc
love the car
the #2 memory drivers side does not work, does not beep. i tried the above it failed.
i have a nice warranty but i would like to fix it myself if possible
ideas?
thank you.
Can you share the name of the warranty company you are using.
Old 11-02-18, 01:30 PM
  #55
DshngDaryl
DshngDaryl's Avatar
I bet if you start your own post, aka a new thread, you will get a bunch of replies
Old 11-22-18, 10:06 AM
  #56
Prnvmj
Prnvmj's Avatar
Default Thank you soooo much!!!!
This sounds like the problem which occurs after power has been disconnected. The seats have to be "re-taught" their limits before the memory will work.
You should check your manual because I think different years have different procedures. Here's a couple posts from another thread:
What you have to do is move the seat back all the way forward using the power seat back switch until you hear a beep , then move the seat cushion back the entire way again using the power seat control, next move the seat cushion all the way forward using the power control. You can now put the seat in the position you desire and push set and #1.
Been searching everywhere to fix this !!!!!
Old 03-17-19, 03:27 AM
  #57
s19sly
s19sly's Avatar
Hi,
As a new owner of this astonishing machine, thanks to this info I have fixed it's one fault.
This works exactly as the Chap says.
Thanks.
Nick
Old 07-20-21, 02:00 PM
  #58
Tman47
Tman47's Avatar
Freakin' genius! Got my car delivered yesterday only to find out my memory seats did not work. NOW THEY DO! Thank you so much for the 'oddball' tip.
Old 09-26-21, 04:12 PM
  #59
amitmunjal
amitmunjal's Avatar
HI
I tried this for my 2012 - RX450h....did not work. Passenger side works fine but the driver side buttons are dead.
Old 09-26-21, 10:41 PM
  #60
elibutton
elibutton's Avatar
For my 2010 SC430 - I set the seats and it beeps when I do that, but when I need to put those seats back and push the memory button - there's no beep. No change.
I guess I will try the instructions listed and see if that will fix it.
Thank you
Quick Reply: Seat Memory buttons stopped working?!
