Interior roof gap
Old 05-30-12, 10:06 AM
husker741
husker741's Avatar
I know it's an old post, but I thought I would bump this up because I have the same problem. Has anyone found a fix or have the same problem with the gap on the passenger side?
Old 05-30-12, 11:41 AM
naked
naked's Avatar
I don't have this car anymore, but the dealership is probably your best bet.
If you really don't want to take it to a dealership, hopefully someone else has some thoughts on how to make the screw tighten more.
If no one responds, then here is the $1 fix answer:
1. Buy electrical tape
2. Open your roof part way so the black connecting 'screw' is revealed on the roof. This is referring to the black 'screw' that goes inside the hole.
3. Wrap electrical tape tightly around the "thinner" part of the screw a few times.
4. Close the roof
That's it, the rattles should disappear
Old 05-30-12, 01:02 PM
husker741
husker741's Avatar
4. Close the roof
It's not rattles that are my problem. Plus there are hundreds of little sensors that make the roof work correctly, and putting anything there could jeopardize the roof from operatelu correctly.
Old 05-30-12, 02:28 PM
naked
naked's Avatar
then what's your problem with the gap?
Wrapping electrical tape around the 'screw' simply leverages the existing torque so it results in a tighter seal. you're asking an owners forum and the historical consensus is take the car into the dealership to get it fixed properly, otherwise the electrical tape solution is a simple temporary fix. for what it is worth, the operation of the lexus top does not have "hundreds of little sensors."
Old 05-30-12, 03:04 PM
bacardi
bacardi's Avatar
bob
i think your needed on this one. what do you think?
Old 05-30-12, 08:20 PM
husker741
husker741's Avatar
I was asking the forum if anyone got any word back from the dealership to see if it is actually a problem. I'm not really sure why you are questioning anything I'm saying. Thanks for your help, but I'm looking for a different answer.
Old 06-07-12, 09:29 AM
husker741
husker741's Avatar
Bump for some help. I found something out yesterday. I was driving 60mph and pushed up firmly on the roof with my fist on the passenger side, and made the wind noise increase heavily. I did the same to the driver side roof (the side without the gap) and the wind noise stayed quiet. Then I accelerated to 90mph and the wind noise on the passenger side became very loud and even overtook the radio. I hope someone can help!
Old 06-07-12, 09:41 AM
bacardi
bacardi's Avatar
husker
i think it has something to do with the roof not locking down tight.
Old 06-07-12, 09:42 AM
husker741
husker741's Avatar
Originally Posted by bacardi
husker
I'm pretty sure that's the problem, but I am just wanting to know if anyone figured out what the dealer would do to fix it.
Old 06-07-12, 12:29 PM
barncat
barncat's Avatar
I thought there were adjustments for the roof?
Old 04-28-13, 03:57 PM
ShawnOk
ShawnOk's Avatar
Was there ever any solution offered from the dealer on this problem? I've noticed that ONLY my passenger side also has a finger sized gap at the joint. Anyone ever get any more information or a solid repair for this issue?
Old 04-28-13, 04:54 PM
jzwu
jzwu's Avatar
My 2002 has the gap on the passenger side roof too. But it does't concern me as much as the fact that the driver side roof seems to be too tight/low so the driver side door cannot be closed if the window is all the way up.
I have to crack the window a little to close the door. Not sure if this is related to the passenger side roof gap. I think it is because the roof is now not aligned evenly on both sides.
Old 04-28-13, 08:08 PM
bacardi11
bacardi11's Avatar
anyone find a fix for this problem?
ut2sua
RX - 4th Gen (2016-2022)
16
01-31-19 10:49 PM
mak89
12-20-17 11:21 AM
e-man
Automotive Care & Detailing
06-29-09 01:04 PM
mtlis250
06-13-06 01:03 PM
itsZep
GX - 1st Gen (2003-2009)
06-08-05 11:55 AM
Quick Reply: Interior roof gap
