AFS OFF warning light
Old 08-21-10, 09:40 PM
Bon
Bon's Avatar
Default AFS OFF warning light
When I picked up my '06 SC from the body shop the AFS OFF light was illuminated on the dash. I had to pull out my owners manual and look it up. The first page I found says: "Indicates a malfunction in: 1) The adaptive front lighting system; or 2) The automatic headlight leveling system if the light flashes."
Well, since I know that the body shop had the battery disconnected I suspected that they threw a trouble code putting it back on. I dug around to find out how to clear the AFS OFF code and most said it required the dealer to reset it. I reset the ECU but it didn't clear the trouble code.
I then went back to the manual and found another page that clearly shows the AFS switch located down with the hood, trunk and gas release buttons.
They had pushed the AFS OFF button while they were fishing around for the trunk or hood release. Problem solved, whew!
The following 5 users liked this post by Bon:
Drivingone (02-13-21), joemg (11-09-21), salju (06-23-20), Sungirl (02-21-20), TitanG545 (06-11-20)
Old 12-06-16, 05:37 AM
sixonemale
sixonemale's Avatar
Funny, I had the battery replaced on my wife's SC the other day and the exact same thing happened after replacement of the battery, the AFS OFF light illuminated on the dash. I struggled to figure out how it became illuminated and even searched for codes. Exactly like you've said, the AFS OFF button is located near the trunk release and also located near the OBD2 scanner input. The person from Triple A who replaced the battery inadvertently hit the AFS OFF button, glad it's resolved.
Old 11-07-21, 02:32 PM
doobs
doobs's Avatar
This place is awesome. Just ran into this problem after working in the car yesterday.
Thanks!
Old 11-09-21, 08:23 PM
joemg
joemg's Avatar
Thats funny, I remember when I bought mine that light was on and after some googling I realized I just needed to press the button, lol.
Old 11-10-21, 09:27 AM
DshngDaryl
DshngDaryl's Avatar
What is AFS?
Old 11-14-21, 11:45 AM
ADSPRU
ADSPRU's Avatar
Originally Posted by DshngDaryl
What is AFS?
levels out the HID beams…. Definitely a novelty… it’s supposed to keep your headlights even with the horizon during aggressive driving
Old 11-14-21, 12:20 PM
Bgw70
Bgw70's Avatar
What is AFS?
AFS=Adaptive Front-lighting System
your lexus has the automatic adjusting headlight system. known as AFS. it has modules and sensors and actuators that allow the headlights to move left and right as you turn the car.
Old 11-15-21, 09:44 AM
DshngDaryl
DshngDaryl's Avatar
Thanks. That is the system that used to creak when someone got into the passenger side of my car. The sound came from right under the driver's side door hinge (in case anyone has a mystery creak)
Bgw70 (11-16-21)
Old 12-15-22, 09:51 AM
lewle
4th Gear
lewle's Avatar
mine auto level but don't move left or right
Old 12-15-22, 07:47 PM
GmanSC
GmanSC's Avatar
It only moves when you turn left or right.
Old 12-16-22, 05:43 AM
Bgw70
Bgw70's Avatar
and only if it’s a 2006-2010.
2002-2005 don’t move left or right.
Old 12-16-22, 02:42 PM
lewle
4th Gear
lewle's Avatar
my sc430 is a 2007
goodfood
05-27-17 08:37 PM
See5
09-02-13 03:18 AM
rmr882
06-03-11 11:32 AM
0l33l
Performance & Maintenance
03-15-09 02:57 PM
siestaguy
RX - 1st Gen (1999-2003)
03-08-08 12:57 PM
Quick Reply: AFS OFF warning light
