Help removing radio
I bought a Vais SL2i-UP and am in the middle of the install. I removed the seat heater switch and the top cover for the console. I see the 2 bolts on the bottom of the radio but don't know how to get to the top bolts. I am afraid to pull any harder on the climate control assembly. Can anyone help with directions?
download the Word document in this link https://www.clublexus.com/forums/sc-...tc-w-pics.html
I followed it to install my VAIS SLU.
Thanks guys. The write up was great. I figured out if I pulled more from the top of the unit, it came out easier. Everything works as advertised but the door covering the radio no longer works when I push the button. Everything is plugged in but I guess I messed up a wire or something. I am going to enjoy the music and try to find that problem when it cools off. It is way to hot here in Texas. Thanks again for the quick replies.
so i got it out and the radio too and then realized the wire i needed for the SC430 was not with my SLU (bought it used) another wire is there probably for use with another model...now i gotta call viastech
I put back the whole thing but this time didnt fully push in the AC controls.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
