Engine Swap?
Without going into too much detail I may have the opportunity to buy a ISF, which was totaled and then improperly imported to the US. I am trying to buy it figuring resale on the parts would be worth it. Does anyone have any idea how hard an engine swap would be? A friend / Mercedes mechanic thinks it could be a go with a custom wiring harness, if I can salvage the entire motor, fuel pump etc.
Interesting situation. My understanding is that there exists little or no previous experience to draw from. As a engineer I could offer that the mechanical aspects of a project like this could be more or less straightforward but the devil may be in the details of the electronics and communications. If I were confronted with this opportunity I would find someone who could provide assurance that there would be enough compatibility between the engine and electronics on both vehicles. I assume that the transplanted engine would include the engine ECU and all related sensors. Because the ECUs communicate on a network, compatibility may even be needed at the software level - i.e. the two systems from different vehicle lines and vintage would need to understand commands from each other to function correctly - in addition to being just electrically operable. What I'm getting at is that a successful solution would yield an awesome result but the technical details could make it cost prohibitive. Just so you know, I am usually regarded as somewhat of a wet blanket when looking at risky opportunities, so consider the source and get plenty of additional opinions!
That's unfortunate. It wouldn't have to be impossible - one of the principles of good systems engineering is to collect major pieces of functionality together and them connect them with the simplest possible interface (like engine-to-chassis). If you could count on an automaker to do that, plus adhere to some standards and open up the communications, you'd see more of this kind of thing. But today there is such a high level of integration of systems in automobiles that they're starting to be compared to aircraft in complexity. (But then aircraft seem to have standards and open networks - e.g. ARINC protocol - hmmm.)
