Just replaced rear differential fluid myself, observations.
Just replaced the rear differential fluid myself on both my 05' LS430 and 06' SC430, here are my observations that I like to share with you guys.
On my LS430, is been 30k miles since the fluid was changed, so I decided to change it. I had the dealer did it last time because I was busy and the car happened to be at the dealer.
The procedure is very simple, is nothing to it, drain the fluid by removing the drain plug and fill up the case with the fill hole. I put in roughly 1.8 Qts of Valvoline Synpower Full synthetic gear oil 75-90W.
The observations is, the fluid is still very clean, I can hardly tell it got any dirtier at all. My theory is I drive this car very gently, I rarely floor it, it is mostly cruise at the speed limit.
I am continue to be unimpressed with the quality of Lexus dealer's service work. My theory is still correct, the only way to have anything done perfectly, is doing it yourself. The fill plug is half stripped and there are 2 washers on both the drain and fill plug, which means the guy put a new washer on without removing the old washer
Luckily there is no leak. He did get the fluid level correct and the plugs are on with the correct amount of tightness. But still when I pay their ridiculous service charges, I expect the work to be 100% perfect. Nope, far from it, the typical rush it thru as fast as possible type of work
I am so glad I did it myself this time. And my service advisor kept bugging me about letting them service my car. I be sure to let him know the crappy job they did on it and that is why I work on my car myself as much as I can ![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
On the SC430, the thing I didn't like was both the plugs was on super tight, is like they tighten it with a huge breaker bar
At least there is only one washer on each plug. The other curious thing is the fluid is starting to look unclear, and it had only been 15k miles on these fluid. It makes me wonder if the dealer really changed the fluid like they said they did
Since the fluid on my LS is still very clear at 30k miles. But I do drive the SC a lot harder then my LS, so that might explain the difference in the fluid dirtiness.
That's it, oh and the LS got a lot more room to work with then the SC, both differential looks identical as expected![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I went ahead and checked it again at 320K miles miles but didn't change it. Same result. Current fluid is the same color and approximate viscosity as when I first put it in. There's a reason why there's no change interval specified.
On my SC430, which only has 23K miles on it, I doubt I'll ever do anything but check it. I will however change the WS atf at 30K miles.
Wish that was the case with my SC430. Bought it last year with 95,000 miles. Changed the rear differential fluid at 98,000 miles. This car had the Synthetic tag on the differential. Fluid came out very dirty and my guess was that it was never changed. Filled it with Valvoline SynPower 75W-90 Synthetic gear lube. I will be changing it again this summer after approximately 9,000 miles. Hopefully it comes out clean this time or I will be doing it again next summer.
BlueCrabby
RX - 1st Gen (1999-2003)
09-04-15 07:10 AM
BNR34
11-08-14 04:54 PM
