Disconnect Power Antenna???
Old 12-30-10, 12:12 PM
  #31
cyberlexus
cyberlexus's Avatar
Since the original is being replaced with stubby antenna, did you need to unplug the power?
Old 12-30-10, 02:12 PM
  #32
redliner8
redliner8's Avatar
You don't have to. I unplugged it because I wanted it to stop making noise when I changed radio stations. Also, it's not powering anything anymore.
Old 12-30-10, 02:15 PM
  #33
redliner8
redliner8's Avatar
Originally Posted by mandyfig
When the Camry was totalled, I yanked the antenna out, like I have a place to put it. It just looks good.
Haha, I definitely agree!
Old 02-02-11, 08:54 AM
  #34
redliner8
redliner8's Avatar
Bringing this post back to life for iamthedoor and I have a question...
I'm considering putting the old antenna back on but keeping it unplugged so it doesn't extend. After some use, I realized the stubby antenna I installed gets about 50% reception because it's only installed for the looks. I took out the oem extending antenna and there was a hole where it used to be (I kept the antenna housing and everything there), the hole is about the diameter of a penny. So, my stubby antenna didn't have anything to screw into. It's pretty much just sitting where the hole used to be. I'm guessing the screw needs to be in contact with something in the antenna housing? I'm not sure how to get that contact or what to contact. I can solder a wire to the screw then attach the wire to something in the antenna housing? Any thoughts? It's hard to explain without pictures so I may take it apart on Sunday and submit some pics to show the problem.
Sample of the antenna with screw:
Old 02-18-11, 07:51 AM
  #35
redliner8
redliner8's Avatar
Is this the only part of our antenna that is used to get radio reception? I saw some other plugs plugged in the antenna that are used to power the motor and i dont know what else...Name:  P1010022.jpg
Old 02-18-11, 08:04 AM
  #36
Poqman
Poqman's Avatar
Yes. Looking at your picture reminds me of my similar repair last month. The power cable and the antenna cable were the only two connections. Heads up. I didn't get my antenna cable pushed all the way in and my reception was bad. Had to take the trunk liner out again to push it on better.
Old 02-18-11, 08:16 AM
  #37
redliner8
redliner8's Avatar
thanks for the quick response, this antenna is driving me crazy haha let me tell you what im thinking of doing and let me know your thoughts.
I want to use something like this antenna instead. i would plug the antenna jack into the existing jack (where the arrow is plugged into). then plug the other two wires (ground and power) into the power source that is only on when the radio is on?
http://cgi.ebay.com/ebaymotors/Unive...#ht_2950wt_859
Old 02-18-11, 08:49 AM
  #38
mandyfig
mandyfig's Avatar
To do the stubby antenna right there should be an adapter you can get. I did my Honda S2000 antenna upgrade on my Camry (which had the same kind of antenna as the SC) a while back and I used an adapter and it worked like a charm. I actually have pics from that DIY...
Old 02-18-11, 09:18 AM
  #39
redliner8
redliner8's Avatar
the adapter is something that I'm having a hard time finding lol pictures would be good, or even what parts I need to do it right
Old 02-18-11, 01:09 PM
  #40
Poqman
Poqman's Avatar
So I'm guessing you would mount this behind the trunk liner and the adapter you're looking for would totally blank off the existing hole in the fender and be painted to match the car? I can't say I've seen such an adapter.
Old 02-18-11, 04:25 PM
  #41
redliner8
redliner8's Avatar
Right now I have the stubby securely fastened onto the hole where the extending antenna used to be (its not wired to to anything). Now I was thinking of attaching this http://cgi.ebay.com/ebaymotors/Hidde...#ht_2997wt_939 to the antenna plug inside the trunk liner so I can still get good reception.
Old 02-18-11, 04:41 PM
  #42
i2fat
i2fat's Avatar
Keep at it guys, I'm interested in the results !
Old 03-12-11, 02:52 PM
  #43
redliner8
redliner8's Avatar
iamtheodor, it works. The stubby antenna is solely used for looks, then I plugged this into the antenna reception cable: http://cgi.ebay.com/ebaymotors/Hidde...#ht_2997wt_939. I ran the cable all the way into the rear passenger seat headrest, so it could get better reception than just sitting in the trunk.
Old 03-12-11, 04:30 PM
  #44
i2fat
i2fat's Avatar
Good to hear! So you have 2 antennas then? One for show and one that's inside the car that actually picks up reception?
Old 03-12-11, 06:04 PM
  #45
redliner8
redliner8's Avatar
Right...I couldn't figure out how to get the stubby to receive reception.
Quick Reply: Disconnect Power Antenna???
