Megan EZ Coil-over install
#46
You could make the hole bigger and stick something like this on top. Seems like there would be enough clearance for the ****.
http://cgi.ebay.com/ebaymotors/LEXUS...#ht_1831wt_913
Or you could raise the trunk lining by putting something underneath it, then your original cap would probably clear the ****.
Just my 2 cents...
Just my 2 cents...
#47
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#49
Hi scdroptop. I didn't think mine touched either until I cut the hole. I've wondered if there is a difference in the LP design versus the EZ. Or if yours touches and you can't see it. The height of the car doesn't play into this. When the coilover is installed, the height of the studs and adjustment ***** are controlled by the design. I didn't know mine were hitting the bottom of the trunk liner. You don't notice the liner is out of place by 1/4" when it is all installed.
What made me look is I first noticed the ride had gotten harser, which made me want to make an adjustment, thus lead me to cut the hole. When I removed the liner and checked the settings, the driver side had gone from 7 clicks to zero. The passenger side went from 7 to 4 clicks. I can only explain the reason why the settings changed was because the liner was pressing down and vibration caused the ***** to screw in.
#50
Poqman any tips or how to take that liner off would be appreciated, I looked at it briefly and can see a couple of clips but not much else that could be holding it on.
#51
scrdstr, Glad to help. I took a photo from another thread and numbered the order I remember removing the pieces. There were also four tie down rings not shown, but it's obvious when to remove. Hope this helps.
![](https://www.clublexus.com/forums/members/poqman-albums-megan-coilovers-picture16000-trunk-liner.jpg)
#52
If you go to this thread https://www.clublexus.com/forums/sc-...ast-night.html and comment #5. I posted a PDF called rear bumper...page 2 of the PDF has an exploded diagram of the trunk garnish components and all the clips holding it together.
#58
Can anyone take pictures of your height and also what yuor coils look like so I can eyeball where to make the adjustments the first time?
#60
Just finished installing my EZ's.... Pretty happy with the trunk liners cutout!
