Map/Dome Light Replacement??!!
Old 04-25-18, 05:33 AM
  #31
hoffy5
hoffy5's Avatar
Hi BGw70!
Do you think this is the same?
Amazon Amazon
Also thanks for the info on the Hood Lock! Yea there is no door adjar warning for that!
Thanks again!
Bob
Old 04-25-18, 06:40 AM
  #32
Bgw70
Bgw70's Avatar
Originally Posted by hoffy5
Hi BGw70!
Do you think this is the same? https://www.amazon.com/Partsam-Inter...65e589d5bbe293
Thanks again!
Bob
those will not fit the SC430 dome light...we have the bayonet style light.
And they must be reverse polarity. This only matters with an LED light. Polarity does not matter when using Incandescent bulbs.
Old 04-25-18, 06:48 AM
  #33
Bgw70
Bgw70's Avatar
Read this thread...I thought we had a good sticky on this subject...we should.
here are all the bulb types in the SC430.
https://www.clublexus.com/forums/sc4...-exterior.html
Old 04-25-18, 06:59 AM
  #34
Bgw70
Bgw70's Avatar
This one says it will work in our cars...
BA9S is the style of plug with the bayonets.
t10 I think is the light type.
i am using this flat style in my 2002 SC430, but I have not used this particular led or from this vendor.
I need another set for my 2007
https://www.ebay.com/itm/12-SMD-1210...7&vxp=mtr#rwid
Old 04-25-18, 07:10 AM
  #35
Bgw70
Bgw70's Avatar
Old 04-25-18, 07:34 AM
  #36
Bgw70
Bgw70's Avatar
I might order these but I have a feeling 2.3in x 1.5in will be too large.
anyone want to go measure the Dome/map light opening?
i would, but not home with the car.
https://www.ebay.com/itm/10x-High-Po...1XkJVw&vxp=mtr
Old 04-25-18, 03:40 PM
  #37
Natroth
Natroth's Avatar
Default too big I think
I bought these, they are smaller and just fit so I think the ones you are proposing will be way too big for the space
Old 04-25-18, 05:00 PM
  #38
GmanSC
GmanSC's Avatar
Default Panel LED
Why would you consider the panel LEDs? They are not any brighter and harder to install or replace.
Old 04-25-18, 05:51 PM
  #39
Natroth
Natroth's Avatar
I have just installed these to move away from the dull yellowish glow of the old globes. They are brighter than the originals. The job was easy, they plugged in and fitted the same as any globe replacement. They give out a square shape of white light but not too bright to be glaring..... (pics above)
Old 04-25-18, 06:38 PM
  #40
GmanSC
GmanSC's Avatar
What I meant was between the panel LEDs and BA9 LEDs, I would choose the latter. They give out the same intensity white light but at lower price and easier to install and/or remove.
Natroth (04-25-18)
Old 04-25-18, 07:57 PM
  #41
VVTiBob
VVTiBob's Avatar
One reason, polarity is easily changed, just flip the modular wire connector. Not possible on bayonet only.
Old 04-26-18, 08:21 AM
  #42
Bgw70
Bgw70's Avatar
This is what several of us are using for dome lights...
Jabberwock (04-26-18)
Old 04-26-18, 08:45 AM
  #43
Bgw70
Bgw70's Avatar
I measured the dome light opening 50x60mm at it narrowest points.
I am going to try both of these sizes...
58mm X 42mm 48LEDs
Amazon Amazon
43mm X 44mm 36LEDs
Amazon Amazon
GregMN (03-11-23)
Old 04-26-18, 06:24 PM
  #44
Jabberwock
Jabberwock's Avatar
I just ordered these because I wanted a more natural looking color temp for the inside map/dome lights.
https://www.ebay.com/itm/6X-Warm-Whi...72.m2749.l2649
Bgw70 (04-27-18)
Old 04-27-18, 12:21 PM
  #45
Jabberwock
Jabberwock's Avatar
Originally Posted by Jabberwock
Received these today. Easy install in the map lights and also removed the tiny light in glove box and replaced with one of these panels. They all work great, the light is bright, not too blue/white, and not overly bright that would unduly hamper night vision afterwards.
In the glove I removed the lensed plastic bulb fixture, and instead plugged the led panel pin connector directly into the connector for the fixture (requires bending Led panel connect pins out at about 45 degrees and inserting into connector) and then wrapped the two with high temp electrical tape to semi-permanently attach. The led panels have self stick backing so peeled and stuck right next to where the bulb fixture had been. Light in the glove box is not actually functional.
The SC map and glove lights are reverse polarity so just reverse the plug to panel connectors if lights won't come on. For $7 bucks delivered for 6 led panel lights (along with the various combos of connecting hardware) this is an inexpensive mod and pretty easy install.
Quick Reply: Map/Dome Light Replacement??!!
