Mileage vs. Time?
This is probably a stupid question, but I am trying to figure out where I am on the recommended maintenance schedule?
2007 - First delivered in August 2007.
5k service done at 2000 miles, 10k service done at 6,000 miles
CPS Inspection done in August 2010, at 12,000 miles (I purchased here)
Now 40 months old and 14,000 miles
What needs to be done/when?
I just did a 'search' for 'sc430,maintenance schedule' and found this old link
that allows you to get a pdf schedule for your year:
https://www.clublexus.com/forums/sc-...-schedule.html
The manual recommends a mileage and time interval prescription of what's recommended for maintenance. Follow as suggested.
Some people here stick by the miles. If I had a hardly used low mileage car, I would double the time and do the recommended items. For example when they ssay 6 months, I would use 1 year. JM2C.
I've weighed in on this several times over the years and I can only tell you from personal experience of owning a LOT (more than 30 now) of garage queens that it behooves you to keep the fluids, rotors, batteries, wipers, filters and rubber (gaskets, hoses, belts) as fresh as you can...or as recommended by the mfg. That's why they say 30k or 36 months.
So to answer your question, if it was me, I absolutely without a doubt would get a 30k/36 month service done. Think about this-you are driving on nearly four year old coolant, tranny fluid, breathing in four year old cabin filter air...your intake is being blocked by a four year old air filter, etc etc etc. I have seen my share of parts fail as well as fluids and filters and brake rotors and batteries due to father time...not just mileage. I'm assuming your car is garaged, but many don't have a garage. The entire car is still exposed to the elements. Some garages in extreme climates don't do enough...the car is still being exposed. IMO that's why Lexus and other car mfg's are smart and do the mileage or timing. I follow it...period.
Don't trust me though...see what Lexus has to say about this issue:
https://secure.drivers.lexus.com/lex...ce-schedule.do
Thanks for the help, I'll try to be a bit more specific.
Both the 18k and 30k have 14 items to inspect, am I correct in assuming that the CPS inspection at 12k covered those?
The 36 month 30k service includes replace air conditioner filter, brake fluid, and engine air filter. It also includes inspecting brake pads and rotors.
Do I need these things done now or at 18k; or should I just wait until I get near 18k, change the oil, check/rotate the tires, and hold off on the other stuff til I have more miles?
Agree ^^ Plus 2. The cost to perform the routine maintenance is a pretty good investment in prolonging these (soon to be) classic cars.
I appreciate your experience - I'll get the 30k service done (when I hit 15k), and it warms up here a bit!
It's garage kept - I was just confused about what needed to be looked again after the CPS inspection, etc.?
You mean CPO? What's CPS? If your car is a CPO then I change my answer...you've already had the 30k service. Let us know.
Pull your maint history on your car and cut/paste it on here so we can see it. My CPO (and all the others I've seen) go through the rigorous 162 point inspection process and revitalization...See link here: https://www.clublexus.com/forums/sc-...ned-sc430.html
When I bought my car in Oct 09 it had the 30k done as part of the CPO process about a month before they sold it to me. The only other regular maint I've done since then is added a new K&N, cabin filter...both which managed to get a little dirty in just a years time and less than 1k miles! Go figure. Check it out...
Dealer Reported 09/09/2010 Arlington Lexus in Palatine 13052 0175391 FOUND #4 SPARK PLUG, EXCESSIVE CARBON BUILD UP. REPLD PLUG.
Dealer Reported 09/09/2010 Arlington Lexus in Palatine 13052 0175391 LOANER CAR # 36H
Dealer Reported 07/24/2010 McGrath Lexus of Westmont 12333 0531628 NON-OEM THEFT DETERRENT SYSTEM INSTALL/R&R
Dealer Reported 07/12/2010 McGrath Lexus of Westmont 12333 0529683 CERTIFIED PRE-OWNED PDI
Dealer Reported 05/25/2010 McGrath Lexus of Westmont 12045 0525423 AUTO DETAILING
Dealer Reported 05/18/2010 McGrath Lexus of Westmont 12045 0524626 USED CAR INSP
Dealer Reported 06/15/2009 Bredemann Lexus in Glenview 8400 0987865 TIRE PRESSURE LIGHT
Dealer Reported 04/03/2009 Bredemann Lexus in Glenview 6816 0968414 EMERGENCY ROADSIDE
Dealer Reported 04/03/2009 Bredemann Lexus in Glenview 6822 0968422 ENGINE OIL
Dealer Reported 04/03/2009 Bredemann Lexus in Glenview 6822 0968422 BATTERY/COIL SPK PLUG
Dealer Reported 11/12/2008 Bredemann Lexus in Glenview 6613 0930777 EMERGENCY ROADSIDE
Dealer Reported 11/11/2008 Bredemann Lexus in Glenview 6602 0929807 MISC
Dealer Reported 11/11/2008 Bredemann Lexus in Glenview 6602 0929807 FRONT/REAR BODY
Dealer Reported 10/01/2008 Bredemann Lexus in Glenview 6107 0918439 10K MILE SVC
Dealer Reported 10/01/2008 Bredemann Lexus in Glenview 6107 0918439 MISC
Dealer Reported 10/01/2008 Bredemann Lexus in Glenview 6107 0918439 SUBLET
Dealer Reported 08/29/2008 Bredemann Lexus in Glenview 5892 0910343 SPECIAL SERVICE CAMPAIGN
Dealer Reported 06/02/2008 Bredemann Lexus in Glenview 3815 0885034 EMERGENCY ROADSIDE
Dealer Reported 03/04/2008 Bredemann Lexus in Glenview 2020 0859799 TIRE-WHEEL
Dealer Reported 03/04/2008 Bredemann Lexus in Glenview 2020 0859799 LOANER VEHICLE - RENTAL CAR
Dealer Reported 03/04/2008 Bredemann Lexus in Glenview 2020 0859799 5,000 MILE SERVICE
Dealer Reported 03/04/2008 Bredemann Lexus in Glenview 2020 0859799 FRONT AXLE
Dealer Reported 08/14/2007 Bredemann Lexus in Glenview 507 0805204 PERSONALIZED SETTING
Dealer Reported 05/01/2007 Bredemann Lexus in Glenview 10 0774566 PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
You've had the 30k service then!
I'm reading my copy of the 001014 CERTIFIED PRE-OWNED PDI and this is what was done:
OIL FILTER
ATF MAXLIFE T-IV
GASKET, TRANSMISSION
GASKET
GASKET
FULE INJECTOR CLEANER
WASHER SOLVENT
BRAKE FLUID
SUPER LONG LIFE COOLANT
GEAR OIL (REAR DIFF)
OIL, MOTOR
BRAKE CLEANER
ELEMENT, AIR REFINER
ELEMENT SUB-ASSY AI (AIR CABIN FILTER)
RUBBER WIPER BLADE
RUBBER WIPER BLADE
BATTERY
Ajust parking brake repair lower engine covers and bumper tire and brake pad depth ok within standards
PREOWNED 7.8HRS 30K SERVICE SET RADIO & CLOCK/RESET
Showed mine started on 9/15/09 and finished on 9/24/09
Quite a process!!!
Looks like you are good then...This summer you may want to check your air filter and cabin filter as they can need replacement once a year sometimes. Mine did.
OIL FILTER
ATF MAXLIFE T-IV
GASKET
GASKET
WASHER SOLVENT
BRAKE FLUID
OIL, MOTOR
BRAKE CLEANER
RUBBER WIPER BLADE
RUBBER WIPER BLADE
BATTERY
Quite a process!!!
