Need parts at a good price!
I will be changing the timing belt this spring. Below is a complete list of what I want to accomplish:
Change timing belt = Gates part number TCK298 belt, tensioner, idler - $93.99, Rock Products part number TC906 timing cover seal - $3.12
Change water pump = Gates part number 44085 - $81.79, Fel-Pro part number 35718 water pump gasket - $29.99
Change "all" tension/idler pulleys = Gates part number 38001 tentioner pulley - $15.28, Gates part number 38488 tentioner - $39.79, Gates part number 36026 idler pulley - $42.79
Change drive belt = Gates part number K060888 - $20.79
Change engine coolant = Gates part number 33878 thermostat - $10.29, Fel Pro part number 35555 thermostat housing gasket - $4.62
Change brake fluid
Change tranny fluid
Change pumpkin gear oil
Change engine oil = Dorman part number 092003 EZ oil drain plug - $6.90, Fel Pro part number 70822 oil drag plug gasket - $0.37
Change air filter/mico filter = Beck/Arnley part number 0421645 air filter - $12.70, Beck/Arnley part number 0422049 cabin air filter - $15.50
Change battery
Is there a place I can get all the right parts/fluids for a decent price???
Still need fluids, but all these parts were from www.rockauto.com.
Change brake fluid
Change tranny fluid
Change battery
PM Sewell or Carson, get quotes. Get part numbers 1st. I have seen complete timing belt packages on ebay.
I have ordered from irontoad before, too.
You may want to check the info at this link: http://www.gates.com/brochure.cfm?br...chGatesPopular
PLAYTYM, register with Sewell and shop, you will see the discount automatically for CL members. Good luck.
