LUCKY'S new year mods, painting lights, ecu help please!
Langsdale, I saw your posts previously (btw, great looking SC!) and have been meaning to ask, since it came up again: How did you take the headlight housing apart? I've seen videos of people putting their entire headlight in an oven to loosen the seal and pry it apart, or using a heat gun on the seal.
How did you seal it back on? Just reheat and stick back together? I was thinking about using black gasket maker.
after you reheat it, you can reseal it back with the same epoxy
be careful with the heatgun b/c leaving it too long in spot will melt it
I have baked my headlights in my past two vehicles to install halos and paint. The first time baking your headlights is kind of nerve racking but you get over it.
I cleaned off all the remaining sealant from the clear plastic lenses and the black headlight housings and I resealed them with black silicone from Home Depot.
Now, I am not sure if I want to do mine or not.
Thanks, I appreciate the responses. You'd think it is crazy to put your headlights in an oven, but I guess that's how most people do it. I have some leftover high-temp primer that I used for my calipers and high-temp black engine paint that I may use for it. I'll do it in the Spring when the weather is nicer and make some notes for a DIY, right now it's cold and icy in PA.
When does LB get his eyes back?
I am so glad I did not try this myself! Like everything else our car is just a bit more difficult than most. I believe even langsdale, king of the modders has something rattling around in his lights. The guy doing mine showed me how delicate some of the housing plastic is, and if you pry in the wrong lace you will never get a good seal.
He took a lot of pictures at every stage (a cl member) and judging by his cars, and his living room full of headlights from all makes I am pretty confident.
I am waiting for my bulbs from ijdmtoys before we put lucky back together. I will start a new thread with all the pics, hopefully the mod can add langsdale and scdroptops into a sticky. I will try to post all this weekend.
I've done research on this since I plan to paint mine this Spring. I found a few websites for non-Lexus cars. Any info on the specific temperature and time for SC430 would be great though...? I'll probably try the first one since it seems to be the least amount of heat (paranoid about melting), then up the temp/time if seal doesn't loosen.
This one says 275 degrees for 5-6 minutes: http://forums.evolutionm.net/lancer-...sings-diy.html
This one says 350 degrees for 2 minutes, turn off heat and let it sit oven for another 5 minutes: http://www.toyotanation.com/forum/sh...d.php?t=112247
This one says 275 for 10 minutes: http://www.club-tc.com/forums/appear...san-titan.html
Finally done! Some went well some problems. I have a lot of pics including the bumper drop, I will try to get a post with all on Friday. For those curious why it took so long I have one word.
Ijdmtoys
Ijdmtoys
