View Poll Results: Red or Black?
Red
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
14
50.00%
Black
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
14
50.00%
Voters: 28. You may not vote on this poll
NEED OPINIONS! Red or Black Calipers
Yup weird during the daytime, looks good at nite, but how can you see the calipers at nite? LOL!
No problem. Black with white decals would look good and go well with your rims, or even black with gray decals. I did blue with black decals (I still have to put the decals on...anxiously waiting for Winter to end).
You would paint the entire outside of the side marker black? That'll look good. I've considered tinting mine, so you can still see the side marker lights when they're on. I don't know if it'll work, I've never done tinting so I'm not sure how or what kind to use.
You'll have to let us know how the decals work out...the caliper's surface is rather rough compared to other surfaces. While painting may offer some smoothing of the surface, I'm wondering if there will be sufficient contact surface for a good look?
Location: Formerly Easton, Pa. Bradenton FL, now Osprey Fl.
I've put decals on my 06 VW GTI, the calipers were already red from the factory, so I didn't have to paint them first. I would think that the paint would smooth them out a little. As a matter of fact the wheels that I had on the GTI, I didn't even have to take the wheels off to put the decals on. You wouldn't think that a little decal would make that much of a difference, but I think it does. Dresses them up just a little bit more. IMHO
Black with red or white "Lexus" decals. Since the calipers are rough and to get them just right, you'd have to spend a lot of time sanding them. Think about powder coating them gloss black.
And thanks to everyone else about the rough surface of the calipers. I will look into sanding them before painting and will make sure that the surface is smooth.
Regarding the MGP caliber covers. The only "issue" would be your wheel and its inside diameter measurement. If you're using OEM wheels or tourmalines like mine the are no problems. However since the cover, is just that a cover, it does add a little to the measurement of the caliper and narrows the clearance between the caliper and the inside of the wheel. Other than that, I have been very pleased with them, not only better looking in my opinion than the OEM calipers, but brake dust/grime has been dramatically reduced. That means less time spent cleaning chrome wheels for me.
Thanks, VVTiBob. My '07 has the OEM wheels so it should work out fine. Now the only question remaining is red or black? I've got Black Saphire Pearl with Liquid metal wheels and am thinking red...Is the installation easy?
