SC430 stalls after putting it in Drive
Old 04-23-21, 07:35 PM
buddhi
buddhi's Avatar
Yes, but I have all that, most the time. Just not always.
This is an intermittent problem.
Old 04-25-21, 01:12 PM
jimisbell
jimisbell's Avatar
BTW, the fuel pump failing does NOT produce a code!
Old 04-25-21, 02:03 PM
buddhi
buddhi's Avatar
So that's very interesting. And a good clue like the dog that did not bark.
Old 04-26-21, 06:08 PM
DshngDaryl
DshngDaryl's Avatar
I don't know if I would do this, but they say if you spray carb cleaner near your engine, it will rev if there is a vacuum leak. It is a cheap and easy way to see if u have an engine vacuum leak. I don't recommend it. I would rather just read the codes, since it is much safer.
Old 04-26-21, 06:24 PM
buddhi
buddhi's Avatar
I like that method. I think I'll make a cone out of newspaper and listen for a leak, then spray it and see what happens.
But other than the intermittent stalling, the engine runs perfectly. I put a glass of water on the intake while idling and
essentially no surface agitation. Revved it up and still nothing, all smooth like the commercial.
Scott R
12-09-20 06:51 PM
sschoolc
07-01-14 05:26 PM
Susie
10-06-13 11:36 PM
Susie
11-14-12 09:22 AM
JohnnyCake
11-08-07 01:28 PM
Quick Reply: SC430 stalls after putting it in Drive
