The inside of my tires wear so fast help
It's the suspension on our cars, more specifically the camber of the tires. There is a very good thread on this here: https://www.clublexus.com/forums/sc-...t-in-spec.html Take a few minutes and read the thread and a link I posted.
Oh, BTW welcome to the forum.
I heard about this issue with our cars just before I bought mine CPO in 2008. As part of the deal with the Lexus dealer, I asked them to change my camber settings to as neutral as they could get it. I agreed to sacrifice a little bit of handling so I could use my tires longer. I have run 17,000 miles on new Pirelli P Zero Nero RFTs and there is a lot of life left in the tires without any evidence of uneven wear on the insides. And I don't think my car's handling is that bad as a result.
Another Lexus dealer who was working on my car commented that my tires were in pretty good shape for an SC430. So I am pretty happy with the camber setting changes.
Don't go "neutral". It can be unsafe because you're not allowing much compliance around the turn. You can end up having less contact patch.
Camber is not the source of problem unless you're above -2.0-2.5 degrees. Anything less than that, you need to look elsewhere. If your camber is within an acceptable range, then your toe is usually the problem. People usually mistaken for the fact that camber is the ultimate source of inner tire wear. Having slightly negative camber is not an issue. However having incorrect toe will wear your tires MUCH faster.
Yes, it is free at Firestone after the initial payment for the lifetime alignment. Driving in, wait and drive out, no pay to go.
Alignment was cometed by a top notch shop .. I have a printout somewhere its not that... New 20 inch rims must be the issue.. Again thanks for all the advice
MarcusMIA
Suspension and Brakes
33
09-14-09 10:03 AM
01VaporBlueRX
RX - 1st Gen (1999-2003)
11-11-02 03:16 AM
