Mid-range Speaker Repair DIY (thanks Zgone)
Old 03-09-11, 03:56 PM
  #31
Pnuge88
Pnuge88's Avatar
i guess my midrange is really blown.. i took a look at it today and the cone and everything was in place with no deterioration or anything. 100 dollars for a new midrange speaker! O_o
Old 03-11-11, 11:24 AM
  #32
DChuka
DChuka's Avatar
If I go to Ace Hardware for the replacement clips, what am I asking for? Replacement clips for my car?
Old 03-11-11, 12:24 PM
  #33
mandyfig
mandyfig's Avatar
Go to the clip-fastener section, there are automotive clips. Get a couple of different sizes. Just match the head size of the current clips and you should be able to get the exact size of the replacements. Refer to the pictures I posted.
Old 03-11-11, 01:59 PM
  #34
VVTiBob
VVTiBob's Avatar
Or go online to places like this: http://www.clipsandfasteners.com/Toy...eners_s/13.htm and order the correct ones. You may have to order a few more than necessary, but I've found I'll break one or two doing other tasks so I have a stash on hand.
Old 03-11-11, 03:57 PM
  #35
VIPNiSS
VIPNiSS's Avatar
automotive plastic clips.. if you go to Lowes or Home Depot they have a slide out tray for automative plastic clips.
Old 03-13-11, 10:08 AM
  #36
mandyfig
mandyfig's Avatar
I have to raid Home Depot, did not know they had some. Good deal.
Old 03-13-11, 10:28 AM
  #37
VIPNiSS
VIPNiSS's Avatar
just wanted to report in that i also receive my replacement speakers edges from simply speakers and installed them!!! honestly I would rather of gone this route then the RTV route.. $25 well spent!
Old 03-13-11, 11:02 AM
  #38
mandyfig
mandyfig's Avatar
Tell me more, replacement mid-range speaker for $25? Post the source! Thanks.
Old 03-13-11, 11:16 AM
  #39
VIPNiSS
VIPNiSS's Avatar
here you go.
https://www.simplyspeakers.com/lexus...t-fsk-6x9.html
use coupon code SS10 for 10% off.
Old 03-13-11, 11:26 AM
  #40
mandyfig
mandyfig's Avatar
Wow that's cool. Will keep in mind if my 6x9's need repair. Do they have one for teh midrange?
Old 03-13-11, 11:29 AM
  #41
mandyfig
mandyfig's Avatar
Great site. Wow everything's there.
Old 03-18-11, 09:12 PM
  #42
westxype
westxype's Avatar
I finally got around to fixing my speaker today. The entire woofer was separated. I didn't break those clips near the tweeter. The trick is to push the center in til it clicks through, then you can just pull the clip out. Here's a pic of the clip pushed in and not flush. Thanks forthe pics earlier. Made it so much easier
Old 03-24-11, 06:22 PM
  #43
DChuka
DChuka's Avatar
OK. I'm halfway there...I got the door panel off without breaking any clips. I picked up a stereo installation kit in the clearance area of Walmart for $10 that included a speshul prybar for popping the clips. It worked! My woofer is the culprit. I expected the foam to be bad but it turned out that the cone was separated along one edge.
I'm trying the RTV sealant fix. Now if I can just get the panel back on!
Thanks to all who did this before me and posted info here!
Old 03-24-11, 06:42 PM
  #44
mandyfig
mandyfig's Avatar
What a dumb *** I was! The clip was a PUSH type. Hence I broke them. Now we know. Thanks.
Old 03-24-11, 06:47 PM
  #45
VIPNiSS
VIPNiSS's Avatar
Mandy, don't sweat it. If you never did the DIY then we wouldn't have a thread to even comment on...
Quick Reply: Mid-range Speaker Repair DIY (thanks Zgone)
