Supra TT and LS400 Brake Conversion Anyone?
#61
Oh and maybe how these shims are supposed to be attached (any photos would be greatly appreciated). The diragram seems a little less detailed as the number of plates doesn't match what the numbers of parts in the kit and what's behind the pad and in what order.
The same part numbers (47744 and 47745) look diffferent on each diagram. On the 4 piston is has 2 half circle holes and only 1 part, but on the 2 piston the same part numbers have two plates, one with grooves and one solid without holes at all. Very confusing.
#63
Well some of the diagrams show the two piston system, and other diagram shows the 4 piston system. I have the 4 piston caliper system. This is why I asked the question, b'c my 4 piston system (Link 1) shows the part 47744 and 47745 but doesn't have it in the part list below the diagram. The 2 piston diagram (link 2) shows the same part and does have it in the part list below. When you compare both, they have different pieces (one with half moon, other with the groove and solid plate) but have the same numbers. And in link 3 there is a 3rd completely different kit with the same description (SHIM ANTISQUEAL...) and it has a completely different part number and different number of pieces. . I know there have been a few members who have done this upgrade and would love to hear what I'm not doing correctly or what parts i'm missing. Or is this project just doomed? I'm very confused and honestly, just quite frustrated at this point.
#66
I have the OEM Toyota pads (part number 04491). It was two solid pads, all pressed together. No extra pieces or shims or anything else. Not sure if these OEM ones have the shims already built into them or not and that's part of the problem I'm having.
#67
Shims cause more problems than they solve IMO, and in theory they will cause a slightly softer pedal. Put some heavy duty brake lube on all points where the caliper contacts the pads and the problem will probably go away. If you want to use shims then make sure both sides of the shims are lubed up.
If you still have the problem then the pads are vibrating in the mounting hardware (clips) or the combination of rotor and pad are not working properly together.
#68
Toyota designs these cars a certain way for a reason...and yes, you are missing shims and possibly clips.
If I saw pictures of your setup, showing the pads and calipers plus the abutment bracket, if applicable, then I would be able to provide more information.
I looked at the diagrams and they show shim kits for part 04491. There are two shim kits, one for each engine.
The Toyota parts guy should be able to help...ask him if the pads you have require shims.
Don't sweat this, it's minor stuff and you will have it corrected in no time!
#69
So I stopped by the Toyota Dealership and had a chat with the Parts Department. I explained the situation to the guy at the parts counter so he pulled up the diagram for 1996 Supra TT 4 piston caliper and got the proper part number which turned out to be 04945-14111 (which didn't show up on the parts list on the links i posted- Link 1 previously). Total cost was about $20. Apparently need to install with the arrow towards the front of the car and put the grease between the pad back plate and these shims. Got them today but won't be able to install them for a few days, have a lot on my plate right now. I've attached photos of the parts for anyone who has similar problems.
#71
Found the time and added the shims/antisqueal plates today. Squeal is gone! Knock wood. I'm happy that this problem is solved but I do have another problem that I can't explain. I put it on the back burner as the squeal was the most annoying. I am getting a type of "ratcheting" noise when i apply the brakes. Not sure if it's front or rear but it seems that it's only the left (driver) side. I hear most when I'm driving with windows down and with a wall to my left side to echo it. It does change depending on my speed. The best description I can give is a "tuk.tuk.tuk.tuk.tuk...tuk...tuk...tuk..tuk....tuk.......tuk.........tuk" depending on my speed and when I slow to a stop it spread outs. It only occurs with braking and does not occur when cruising.
#73
....do you have slotted/crossed drilled rotors ? If so, this may be the issue...I had a noise similar to what you're describing & the old pads running across the slots was causing it. I replaced the pads & the noise went away
#74
Hey buddy, thanks for chiming in. Yeah I'm running d&cs rotors but almost all my hardware and pads are brand new. New toyota pads front and rear, new supra front and rear d&cs stop tech rotors, new supra front calipers, oem Lexus rear calipers that came with car, new stop tech stainless steel lines front and rear. I will say though that the front toyota pads sat on a shelf for 6 years. Could that be an issue? Could it just be break in noise since it has only been less than 200 miles?
#75
