Restore the shine of your Navigation Screen
My recently purchased 2002 SC430 had a grimey Navigation Screen that was covered in 9 years worth of rub marks where the common command buttons appeared on the screen.
First I cleaned the screen with a photographic lens cleaner:
Then, after applying a REALOOK screen protector
The screen had a clean glossy almost new look again - Horray!
Yes it does reflect a bit more, but overall it is much easier to read and hides almost all of the old wear marks and scratches.
I will post pics of all of my mods once I get my luxlink installed in a couple of weeks.
I put a screen protecter on my GPS when the car was a week old. I use a eye glass cleaner solution to clean the screen,and it works very well. If the protector gets dull or scratched, its just a matter of peeling the old one off and putting a new one on.The only down side is that the screen does not appear as bright as without a protector on it. In the sun it can be just a little harder to see.But not too much.I would recommend this product.
Katy
Katy
The only semi-frustrating problem with a screen protector is getting the bubbles out.....but it can be done.
The realook surprisingly had very few bubbles that eventually worked their way out over a week. It is thicker than other screen protectors I have applied in the past, so it goes on easier, just take it slow.
I started from the upper left corner of the nav screen and applied the protector downward in a diagonal motion.
This method resulted in very few bubbles that were easily squeezed out to the sides.
I did get overzealous with my plastic scraper on one bubble and that left a few small scratches on the protector film. No Big deal.
Sounds like it might be a good fix,but REALook screen protector is no longer available. On ebay I found a lot of screen protectors made especially for the most popular cell phones and finally found a similar film for larger screens (i.e. tablets, etc.). Wondering if these screens would do the trick (would have to be cut to fit of course). Is the REALook protector a flexible film or is it made of rigid tempered glass?
I did find this product on ebay using the item number you gave.(thanks for that). Have you received it yet? I'm not sure, but the description says it is made of tempered glass. If so it cannot be cut. If I understand correctly, these screen savers are made made in various sizes to exactly fit the popular cell phones and tablets so we may not be able to use them on our NAV screens. I did clean my screen with an eyeglass cleaning pad and it did make an improvement
