View Poll Results: What's an acceptable delay to resolve this glitch?
I want the LuxLink now…NOW, NOW, NOW!
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
14.81%
If a delay of a couple of weeks means the glitch is fixed, it’s worth the wait.
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
22.22%
I'd be willing to wait an additional 4-6 weeks to make sure it’s right.
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
18.52%
However long it takes – Do it once, do it right.
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
12
44.44%
Voters: 27. You may not vote on this poll
About-To-Be New LuxLink Owners - Need Your Opinion/Input
If things get to difficult to please everyone and since the next run of luxlink is most likely the last . WE may have to calculate what are the down sides to the glitch. If it means that Steve would be pulling out from it . I would be willing to accept mine with the glitch. Yes it could be an inconveience for some but if its the only way forward I would live with it as is . Lifes not perfect
I posted this poll because, in my conversations with Steve, he asked me if I'd be OK with a delay if the glitch could be fixed.
I just wanted to see what the general consensus was on this. I don't speak for everyone.
If the glitch can be fixed, I'd be happy. If it can't, I'm not canceling my order or discontinuing using this product. I'll live with it, like I always have.
Last edited by Habious; 04-06-11 at 10:33 AM. Reason: Put too many j's in "canceling"
As others have said...this could be the last run of these and if the glitch can be fixed and field tested...why not just wait.
The story of the rainy night and other issues make me want to wait until…
Could you imagine starting the car in the garage where you may not have the clearance and the roof go down...YIKES!!!
I agree. If the answer is "you just have to live with this glitch", I will...as I have, and just work around it.
John
The LuxLink basically gives you 4 features the the car doesn't have from factory.
A) Allows you to remotely start the car
B) Allows you to remotely raise/lower the convertible top
C) Allows you to do both A & B, remotely starting the car and having the top raise/lower
D) Gives you one-touch (double-click) control with the interior button
The "workaround" for the glitch is essentially..."Don't ever do 'C' if you don't want it to mess up when doing 'A'."
That's basically been my workaround. I don't do the sequence that starts the car AND lowers the top...because I know doing that will cause a problem the next time I remote-start it. There are many, many times when I'd like to do this. But, I've chosen not to...as my "workaround".
However, if we CAN get 'C' to work without messing up 'A' (and, more importantly, not messing anything ELSE up), I'd love the product even more!
Just so we don't scare anyone here, let's be clear. The glitch only happens when you do a double function: car start AND top down. If you stick to single functions, top down THEN car start, there is no glitch.
I don't intend to ever put the top down and start the car in a single function. I'm not even sure why there's value in that, especially because you then have to use the key to manually unlock the door since the remote is locked out at that point.
I'd hate to introduce new programming bugs and so my vote would be to go with the tried and tested as is.
OTOH, I will say that I don't care about delay since like so many, I'm getting this as a backup.
Sure says something about how great the Luxlink is when almost no one has had a failure, yet so many are willing to buy one as a spare "just in case."
OPERATING INSTRUCTIONS FOR SC430
LuxLink® Luxury Vehicle Remote Control
TO USE REMOTE START
1. Press Unlock Button first one time.
2. Press Lock button two times to start.
Note: You have 3 seconds to unlock the doors before the ignition is turned on. When the ignition is turned on the remote is disabled and the door will have to be unlocked by using the driver’s door cylinder.
3. Press Unlock Button within 2 seconds to unlock Driver’s Door, or press Unlock Button 2 times to unlock both doors.
Note: For security: Unlock must be pressed before starting, to prevent alarm from going off.
Note: Key must be put in ignition and turned to on position prior to stepping on brake pedal or engine will stall.
Note: After approximately 15 minutes of running, vehicle will automatically turn off.
Note: Have FUN! Show it off! Heat up or cool down your cabin whenever possible by starting the car early!
Note: Hood pin must be closed in order for remote start to operate.
TO USE REMOTE TOP
***CAUTION: The only way to stop the remote top while in motion is to turn the key to the lock position in the driver’s door key hole or by pressing the inside top switch.
4. Press and hold Unlock Button for approximately 3 seconds till a long audible beep is heard.
Note: Once you have heard the long audible beep, you have approximately 2 seconds to press the lock button and lock the doors. After the top has completed its cycle, the doors will be locked and the alarm will be armed.
Note: LuxLink detects what position the top is in, therefore will open or close the top accordingly
TO OPERATE REMOTE TOP AND STARTER SIMUTANEOUSLY
1. Press and hold Unlock Button for approximately 3 seconds till a long audible beep is heard then immediately press the lock button 2 times. (Timing is crucial)
Note: The engine will first start then the top will either open or close.
the top accordingly
TO OPERATE REMOTE TOP ONE TOUCH
1. Press the inside top switch 2 times to either open or close the top.
Note: You can stop the top by pressing the opposite button one time.
TO OPERATE REAR QUARTER WINDOWS
1. Press driver’s window switch down 3 times.
a. Window’s will either open or close.
b. Wait at least 5 seconds between each window motion.
Note: The rear quarter windows alternate between up and down. If window does not move on the first try wait 5 seconds and try again. Rear windows do not have the ability to recognize if the windows are in the up or down position.
I was about to post "In your face!" to JohnnyCake so, I think you're good. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
PLAYTYM, thanks for finding that. I was just looking for it!
Nice to know I'm not crazy...at least not in this particular, narrow instance.
I certainly agree that it's a totally different problem if you live someplace where it's always sunny and 82°!!
I've had the top go down "uncommanded" when I started the car on a rainy evening.
At that time, it was more than just "a little annoying"!! It dumped a mess of water (from the back window and roof) into the trunk of my car (and onto my CarPC). Not to mention, my seats got wet from the rain coming down, until I could put the top back up.
