sc430 tanabe lowering springs
my friend gave me a tanabe lowering springs model TNF089. i did some research and found out , this part number is for a 2002-2004 sc430. My car is 2005. need help with more info. Will this fit my car without any problem? thank you
Front suspension - Suspension components - Coil spring Coil spring, sc430 2002 - 2004
Part Number: 4813124601
Front suspension - Suspension components - Coil spring Coil spring, sc430 2005 - 2010
I only post the front RH side, but you can already see the parts numbers are different.
They don't import the 05+ lowering springs from Japan probably the demand is too low.
I read the Japanese specs sheet years ago and I remember it only said the length was different. It said nothing about the fitment tho.
Why don't you give it a try since you got them for free?
p-bateman
09-07-09 04:15 PM
