Power Antenna to Fixed Stubby Conversion
Old 04-21-11, 06:19 AM
redliner8
redliner8's Avatar
Does anyone know if there's a cable that you could screw the antenna into the other end? That set up would work.
So that this
screws into the female end of this:
Old 04-21-11, 07:35 AM
mandyfig
mandyfig's Avatar
Keep thinking....
Old 04-21-11, 07:40 AM
redliner8
redliner8's Avatar
I'll let some others think lol Hurts my head after thinking about it for a month...To get a glimpse of what I've been through: Right now I re-routed the antenna cable into the interior of the car, routed it into the backseat headrest, and connected it to a dissassembled shark fin antenna hahaha
Old 04-21-11, 09:25 AM
mandyfig
mandyfig's Avatar
I have seen your posts in other threads, you really want this done!
We will get there.
Old 04-27-11, 05:15 PM
redliner8
redliner8's Avatar
My stubby now gets a signal but it still doesn't get as good reception as I like. I attached a long whip antenna and it worked fine (ugly, but worked fine lol). I think the Lexus amp is just too weak to pick up good signal strength using the stubby. I'm not sure how to remedy this.
Old 11-06-12, 07:54 PM
TriniLex
TriniLex's Avatar
any progress?
Old 11-07-12, 03:50 PM
mandyfig
mandyfig's Avatar
Been looking at the new Lexus convertible, it has the right kind of antenna we need.
Old 11-08-12, 08:45 PM
robertrios
robertrios's Avatar
that would be awesome
Old 01-05-13, 09:12 AM
mandyfig
mandyfig's Avatar
Time to bring this back on the table. I think we are near.
chicotrini is close to a breakthrough.
Old 01-05-13, 09:39 AM
mandyfig
mandyfig's Avatar
The bottom line is to be able to shove the Celica antenna in the existing hole and be able to mount the nut (Chrome ring) and it is done. Then we just screw in the S2000 antenna which fits. My S2000 antenna is now mounted on my wife's Miata.
So heck I can use the Miata's antenna as well.
I am getting excited.
Here's the Miata antenna using the S2000 mast. And this is the Miata antenna as well:
Attached Thumbnails Power Antenna to Fixed Stubby Conversion-miata-s2000.jpg   Power Antenna to Fixed Stubby Conversion-miata-ann.jpg
Old 01-05-13, 10:06 AM
mandyfig
mandyfig's Avatar
chicotroni, I think this will work, here's what you need to do:
1. Remove mast per PDF available.
2. Dis-assemble trunk.
3. Remove 1 and 2. Re-use 3 and 4 per picture, see pic.
4. Unplug radio antenna and power into antenna assembly.
5. Use our Celica mast, install with existing 3 and 4. See pics below.
6. Seal the drain hole.
It should work.
Best of luck!!!
PICS:
Attached Thumbnails Power Antenna to Fixed Stubby Conversion-plan.jpg   Power Antenna to Fixed Stubby Conversion-celica-ant.jpg
Old 01-05-13, 10:19 AM
mandyfig
mandyfig's Avatar
I think we can see clearly now!
Attached Thumbnails Power Antenna to Fixed Stubby Conversion-mount-celica.jpg
Old 01-05-13, 11:05 AM
mandyfig
mandyfig's Avatar
Here are more concept shots. Definitely doable with some modification.
The only other thing is how to hold the mast, the Celica mast came with a bracket. This is the minor concern.
See pic:
Old 01-05-13, 01:48 PM
TriniLex
TriniLex's Avatar
Got the celica one off but broke off the celica antenna from it while taking it out.
I will have to drill it out.
Can you link me to the PDF to remove the trunk of the SC?
Old 01-05-13, 02:24 PM
mandyfig
mandyfig's Avatar
There will be a lot of DIY's from the Tail Light Upgrade.
VVTiBob has posted a bunch of DIY's. He also replaced his NAV system and therefore did the same tear down, let me check it out.
Quick Reply: Power Antenna to Fixed Stubby Conversion
