Motorized door for the radio stopped working, popped the cover off and the wire...
Motorized door for the radio stopped working, popped the cover off and the wire was not connected. I don't see what it connects to, can anyone tell me where it snaps in?
If you can provide us with a little more information, I bet we can help you out.
The wire that's "not connected"...I'm assuming this is the wire that goes from the door switch into the dash, correct?
Which end is not connected? Do you have the switch assembly with a pigtail of wire attached to it...and the OTHER end isn't connected? Or do you have the wire dangling loose, not attached to the switch?
Does the "not connected" end terminate in a connector, or is it bare wires (like it was pulled out)?
On the back of the switch for the door there is a black connector that pluged into the switch and I believe that the white connector you have would then plug into the black connector. You may have inadvertenly pulled out the black connector [ This is easy to pull out ] When I was doing install work in the same area as the radio switch I made the mistake of unplugging the connector on the back of the switch instead of just removing the white 2 pin that you have . You may have lost it or else your not seeing the place it plugs into. It is very hard to plug the white conenctor in with the black part I am talking about in place . Take a close look at the door switch assemble and see if you see what I am talking about.
