Wheel Spacers - Yea or Nay?
You should really have a geo done if your changing wheel or adding coilovers..
Recomended by my friend that owns a company called wheels in motion in the Uk that you dont go above a 5-7mm Spacers
The spacers I'll be using are hubcentric bolt-ons. They are not just spacers that slide on the original studs.
SteadyEddie...I have 25mm in the rear, nothing in the front, yet. Never had any problems. I'm running stock wheels. I have the ones that have the lugs already installed, take off the wheel, install spacer, torque, then put on wheel and do the same.
Location: Formerly Easton, Pa. Bradenton FL, now Osprey Fl.
SteadyEddie, you convinced me to try your setup. I also kept the OEM setup when I got aftermarket wheels, but was never happy with how the rears looked tucked in. I got my 25mm spacers today and installed them on the rear. Now the front and rear are inset the same 5/8" from the fender. Looks sooo much better. Not as aggressive as some of the other setup's, but I like it![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I drove our RX last night and followed my wife home driving the SC. The rear tires on the SC looked like they were running with negative camber. I never noticed this until I added the spacers to the rear. Before adding the spacers, the tires were too recessed to see if there was camber, so I'm wondering if it was always like this or did adding the spacers throw off the alignment. Anyone know if adding the spacers means getting another alignment?
Geez, I really wouldn't think so especially if they are hub-centric bolt on spacers. I mean it's no different than simply putting offset wheels on, except this way we can rotate our tires.
Plus 2^^. Makes sense.
mdgrwl
03-10-09 06:06 PM
