Injen Short Ram Intake Install Buggin' Me
#77
When I shop, I don't look at the sellers' misleading photos and prices only, I always check the part numbers.
Most members probably don't know that Weapon-R makes two different intakes for the SC430.
One costs almost 70% more than the other one.
I haven't seen anyone here bought the more expensive one yet.
http://www.eracingworks.com/Weapon-R...1-p-39001.html
http://www.eracingworks.com/Weapon-R...1-p-38272.html
#78
I've never heard any sc430 member who had installed weapon-r reported that issue so far, but I do see weapon-r intake would give you less room for clearance there.
This type of heat shield only blocks some radiant heat from the engine… It does very little (read nothing) to direct cold air to the intake when stuck in traffic… If you’re not “ducted” to the front of the car, believe me, you won’t get much “cold air” from anywhere under the hood!!!
An added bonus is injen gives me more clearance to change bulbs, belt and etc.
If you are mainly looking for performance gain, don't buy it.
#79
I'm pretty skeptical about any performance gain. With the sheer volume of air the engine sucks in, it's going to pull air right around the "heat shield." I'll bet anything that the temperature will be exactly the same on both sides of the shield with air flow. I ordered one purely for the sound.
#80
As with Talwang and liquid SC, I bought mine only for the "sound effect".
Some prefer the look with the heat shield, and that's fine. But I don't see how it could improve the performance. And building a real cold air duct to the front of the car is IMO waaaaaay too much work if you ain't racing.
#81
Don't buy this if you expect an abvious HP (or torque) gain.
You'll probably get better throttle response by driving around with an empty fuel tank (vs a full one, 200 lbs difference).
#82
I bought the Injen for the growl that everybody's testified to.
As it is, I punch on the gas pedal to hear that little growl. At least with the Injen, the growl will heard better and maybe I will let up on the gas (doubt it).
Can not wait to free up space in there and get that Injen in place.
But 1st need to line up hose clamos!
#83
mandy-sounds like a great saturday morning project! Do it and let us know, take some pics. Thanks! Good luck...yes, get the clamps at HD. I also bought a new large clamp for the heat shield one that broke when I tightened it too much Use a screwdriver not a ratchet.
#84
Hoping it comes in today! I am so ready. Like you, will be doing major cleaning before install.
Is it straight forward? What tubes go where? Did you have to shave the cover? Does it fit perfect?
Got my clamps, I got the 7/8" ones, will it do?
#85
Did not show up, bummer. Have to wait until next week.
#86
A word of wisdom for anyone with a 2004+ SC that's going to fit the Injen. I don't know exactly when things changed but my 2006 doesn't have the hose - and maybe doesn't even have an OBD canister that the 2002-03 SC's do. This doesn't appear to be a big thing but you do have to plug the extra hole in the intake runner with something. I've put in a temporary plug but will be looking for something more permanent and suitable that can handle the under-hood heat. Otherwise all is well. I had to nick off more of the engine cover than I expected but it turned out really well and I'm happy. No codes were thrown yet but I haven't gone very far. It has yet to be determined if this mod has an acceptable WAF.
#87
#88
(No that's not a through-hole in the plug.)
(Yup, I'm pretty pleased with the carving job.)
We took our first cruise to lunch and I purposely avoided goosing the engine so my wife wouldn't be surprised. I'll slowly let it growl a bit more as time goes on and see when she notices. I love the way I can choose when to let it bark but yet I don't have to deal with an exhaust drone when we're just cruising.
BTW: WAF = Wife Acceptance Factor
#89
Bon-great job installing! Great job too with the carving job. I'm very nervous to do that since I have a rare red engine cover. If you get the heat shield it's pretty easy to install and hides (IMO) the ugly blue cone.
The greatest joy of this mod is between 4500-6000rpms when you are in manual mode...especially second gear going up to 50mph or so...very nice!
#90
Is everyone oiling their filter? I've found the Injen cleaner and oil (Protec charger kit) for around $17 delivered. I have some K&N filter oil on hand that I'm about to use.
Scdroptop, I understand your hesitation to dremmel your cover, especially your red one!
