Code P0153 - Help
Code P0153 - Help
I need your help! I got my new cats and headers installed and my car is throwing the code P0153. The code was cleared and came back after restarting the car. I know it has something to do with the oxygen sensor...Any thoughts of what it could be and how to diagnose/fix?
I assume you kept all four O2 sensors, two each bank (one in front of cat convt and one behind). Did you use the old sensors, they are rather delicate and can be damaged if knocked around. Perhaps one of the wires was pulled out of the connector or harness.
A 153 error is the O2 sensor bank 2 (passenger side) sensor 1.
The issue surrounds fuel mix and time to detect and uses second trip logic. ie car warmed up. With the work you had done, most likely problem is a short.
You'll find more info in the PDFs in this thread: https://www.clublexus.com/forums/sc-...-location.html
