low enough?
Old 05-26-11, 03:16 PM
jkt
jkt's Avatar
Default low enough?
Just got my car back with new wheels and tein coilovers installed...I asked for 1/2 in space but was told that would rub? does this look low enough? Also feeling every crack in the road, can the teins be adjusted to a softer setting?
Old 05-26-11, 03:22 PM
jkt
jkt's Avatar
another view
Old 05-26-11, 04:42 PM
robertrios
robertrios's Avatar
i like the back but something looks wrong on the front it dosent look low enough.
Old 05-26-11, 04:59 PM
Pnuge88
Pnuge88's Avatar
yeah you should definitely be able to go lower. what are your wheel and tire specs?
Old 05-26-11, 07:26 PM
scdroptop
scdroptop's Avatar
You can go lower, but I bet you will rub. Listen to the experts if they have done this many times and are a good shop. If you don't care if you rub a little, the rubbing will eventually wear down the inside of the wheel well and it may subside. If it drives you nuts like it did me, then you should listen to them.
IMO it looks great! Leave it alone.
Old 05-26-11, 08:46 PM
Z3NK1
Z3NK1's Avatar
lol
Old 05-27-11, 04:58 AM
jkt
jkt's Avatar
Wheels are 19x9.5 & 19x8.5 275/35 & 245/30 asked for 24 offset. Also got the injen -like the sound!
Old 05-27-11, 10:29 AM
talwang
talwang's Avatar
Did they tell you where the tires will rub?
--> Fenders are the wrong answer. lol
Your setup doesn't look F:8.5" +24 R: 9.5" +24 to me, the offsets look like still in mid thirties.
Old 05-27-11, 11:37 AM
IcEnPinKi
IcEnPinKi's Avatar
slam it to the ground
Old 05-27-11, 11:56 AM
Pnuge88
Pnuge88's Avatar
You can definitely go lower some without rubbing. Take camber into account.
Old 05-27-11, 02:57 PM
Emackny
Emackny's Avatar
ummm.. yeah.. you can def. go lower.
JBLUR
05-07-14 08:09 AM
lexus316
04-14-14 12:31 AM
Amalan
Wheels, Tires & Brakes Forum
14
12-13-11 06:16 AM
Blurr
SC- 1st Gen (1992-2000)
26
02-15-10 03:48 PM
CP_Ree
50
10-01-09 06:08 PM
Quick Reply: low enough?
