fuel filter location
Old 01-12-16, 10:58 PM
SC43052
SC43052's Avatar
Originally Posted by texsexlex
...in the attached files from post # 2, it shows the fuel filter located inside the tank. I didn't see anything posted about it being under the backseat
Read post #12.
It is in the tank but accessed by removed a plate which is exposed by removing the back seat.
Old 01-13-16, 04:11 PM
texsexlex
texsexlex's Avatar
Originally Posted by SC43052
Read post #12.
...lol...thanx for that clarification......just like everything else I do, look at the picture & put it together, then read the directions afterwards !!!
Old 01-14-16, 07:36 AM
kjcole
kjcole's Avatar
Personally, I wouldn't mess with it unless the car was showing signs of fuel starvation.
tank3176 (10-16-19)
Old 11-17-22, 06:32 PM
aharringto
1st Gear
aharringto's Avatar
Default Is250 fuelfilter location
The fuel filter is definitely not a maintenance item on the SC430. However, if you were to experience contamination of the gas tank it is possible that the fuel filter could become fouled and require changing.
Fouling of the fuel filter would not affect gas mileage. If there is not enough fuel pressure available to the injector system the computer would throw a fault code. If you are receiving faults then you should troubleshoot for this possibility. Otherwise it would be a waste of time and money to change the filter.
And unless you are an experienced DIY and have handled fuel lines, changing the fuel filter would not be considered a trivial task.
It is integrated into the fuel pump assembly, which is located in the gas tank. To access it you need to remove the back seat, under which is a floor service hole cover that must be removed to expose the fuel pump assembly. The fuel pump assembly must be pulled from the tank and the fuel lines disconnected (remember you are working in the back seat). Then the fuel filter can be disassembled from the pump on a bench and replaced. In addition a number of gaskets and O-rings need to be replaced during reassembly and installation into the fuel tank. If all of the replaced fuel line connections are not tight the unit will leak gas. And if the sending unit is not replaced properly the gas gauge will not read correctly.
The fuel filter is about $40-$50 (aftermarket), and I would estimate the attendant O-rings and gaskets would be approximately $10-$20 more.
HOw do you replace fuel filter
Old 11-17-22, 07:28 PM
FlopTop04
FlopTop04's Avatar
I did it a few years ago. It's pretty easy. There is an access panel on the drivers side under the rear seat.
Here is a link to my post with the part numbers I used : https://www.clublexus.com/forums/sc4...l#post10894339
kpal
RX - 1st Gen (1999-2003)
07-27-18 03:31 PM
MidPine
12-02-07 11:18 AM
cwu
07-11-07 09:11 PM
ginjuice
Performance
01-12-06 08:12 PM
last993
11-30-03 05:16 PM
Quick Reply: fuel filter location
