Glove Box Light Help
Old 06-10-11 | 11:26 AM
donsmith's Avatar
donsmith
Default Glove Box Light Help
My glove box light is not working. The bulb is OK, the continuity from the switch to the bulb is OK, the switch is OK. All fuses are OK including the 5amp identified for this light. Everything else seems to be working just fine.
I'm not getting any power to the switch via that wire nor to the opposite wire at the bulb. Does anyone know if the wire to the switch (then to the bulb) is positive or if the opposite wire at the bulb is positive? i.e. is the switch positive or negative? Trying to find the break in the wiring, where does the wiring trace back to? Anyone have a wiring diagram of this area?
Thanks for any help.
Old 06-10-11 | 12:27 PM
mandyfig's Avatar
mandyfig
I have the same problem.
Old 06-10-11 | 01:10 PM
talwang's Avatar
talwang
the glove box light will come on if and only if the headlight switch is at least turn to the first clickstop.
The following 2 users liked this post by talwang:
JDaveSC430 (03-10-23), SC430Dad (03-12-23)
Old 06-10-11 | 01:43 PM
donsmith's Avatar
donsmith
Wow, I've never heard of that before. I'm sure that's the solution, I'll verify tonight when I get home. I was trying to resolve something that wasn't a problem, I'm just glad you educated me before I tore apart a wiring harness. Thanks talwang.
Old 06-10-11 | 04:51 PM
mandyfig's Avatar
mandyfig
Gotta try it too!
Old 06-10-11 | 08:16 PM
donsmith's Avatar
donsmith
Works great, thanks.
Old 06-11-11 | 04:39 AM
mandyfig's Avatar
mandyfig
Yes! Works. Thank you.
Old 03-10-23 | 03:29 PM
aaronsules's Avatar
aaronsules
9th Gear
Default Unbelieveable but true
Could not believe but it is solid truth - follow the wiring diagram for info too.
miaristo
02-09-11 04:41 PM
Vadim540i
SC- 1st Gen (1992-2000)
05-19-10 02:13 PM
97 ES3oo
05-08-09 06:28 AM
Vip-ish
09-13-08 05:07 PM
Classified
02-01-07 11:32 AM
