raising the wiper arm??
You could either operate the wipers and turn off the ignition when the wipers are vertical or open the hood.
Best regards
Steve
Best regards
Steve
Run the wipers mid-stream then turn off. Your best bet. Steve is right on.
How do you adjust location of wiper rest?
A Lexus mechanic showed me a technique on how to remove wiper arm. I have to try it first and will let you know, in case you need to re-align your wiper rest position.
Thats the design of the wipers, the only other way as far as I know is to remove the wiper arm altogether and then replace the blade.
Just the nature of the beast. The beast that we enjoy riding.
I removed both wiper arms recently and changed the blades. It also gave me an opportunity to adjust the final wiper(s) resting position.
Running the wipers and then turning them off in mid-stream is a very good idea. Now that they are resting in better positions, I will change the blades that way next time.
iolmaster
05-01-16 07:16 AM
capz1121
RX - 1st Gen (1999-2003)
04-17-13 08:02 AM
