Sc430 trunk and fuel door buttons are not working
Old 04-12-18 | 11:45 AM
VVTiBob's Avatar
VVTiBob
Did some more checking on commonality between the two circuits: both share grounds at the following points: II, BL and BP, where BP is ground connection on the LH quarter panel behind the tail lamp assembly.
Old 04-12-18 | 11:56 AM
DshngDaryl's Avatar
DshngDaryl
Because of the new LED light install, I think this is a distinct possibility.
Where did the new LEDS go? That will help us determine what might have been disconnected. If they were taillights, that makes this even more likely.
If you need into your trunk, or to open the gas lid, there are manual handles for that.
You can open your trunk from the bottom of your glove compartment. There is a little flap that opens revealing a cable pull. Once you are in the trunk, I think there is a release for the gas lid
Old 04-12-18 | 12:24 PM
VVTiBob's Avatar
VVTiBob
Yep, inside the trunk, kind of hidden from view, behind the same left rear taillight assembly velcroed to the garish wall. Only thing different on mine, no pretty pictograph of a gas pump, just a plain black handle with a thin nylon cord attached.
Old 04-12-18 | 02:33 PM
rwenig's Avatar
rwenig
Default Fuel Filler/Trunk Lid Switch
Sounds like an intermittent ground issue, or more likely low voltage at the battery. Have you measured voltage at the battery? And with your description, low voltage is my first guess. See post #15 below.
The battery reads 12.5 Volts withe car off, 14 Volts with it on. So, I will start checking the ground issue -- since it seems like the battery is good.
Old 04-12-18 | 03:45 PM
VVTiBob's Avatar
VVTiBob
Driver’s side J/B connector D-4 for both luggage door and fuel lid
pin 5 ground always 12v
pin 6 ground always continuity
luggage J/B for luggage door release
Pin 14 ground always 12v
pin 16 ground always continuity
Luggage J/B for fuel door
Pin 17 ground always 12v
Pin 14 ground always continuity
pin 5 ground always continuity
Old 04-12-18 | 06:59 PM
VVTiBob's Avatar
VVTiBob
When there is an issue “talking” to the luggage area J/B and if you have a DTC reader you should get a B1263 trouble code to confirm it.
Old 04-12-18 | 07:56 PM
JohnnyCake's Avatar
JohnnyCake
As many times as I have disassembled the trunk, I totally forgot about this. Thanks for the refresh!
Old 04-15-18 | 01:26 PM
Retroplay's Avatar
Retroplay
You didn't mention where you had LED work done, but if it were in the glove box area, you might find that the valet switch is not actually plugged in. If the harness isn't plugged in, the valet switch will act as if you have it on.
The loud beep you heard is a pretty good indicator that the car registered your attempt, but disallowed it.
Old 02-10-24 | 01:42 PM
Bgw70's Avatar
Bgw70
I learned something new today and had no clue this even existed…i was putting the trunk interior back together after i had the new shocks installed and found the fuel door manual release.
The cable in the center console is the trunk manual open
TFBTRADE
01-03-23 01:49 PM
Granite88
07-25-16 06:11 PM
divilish
ES - 5th Gen (2007-2012)
04-25-14 11:34 AM
goku2
19
06-19-13 09:21 AM
rogerw11
11-15-03 03:53 PM
