How to Install Daizen Sway Bar Bushings
Old 06-27-11, 05:42 AM
redliner8
redliner8's Avatar
Default How to Install Daizen Sway Bar Bushings
I know a few people have replaced the OEM sway bar bushings with the Daizens. I was wondering if anyone has install pics or advice on how to install? And how difficult it is? My guess is I'd have to take off each end of the sway bar and slide the Daizens on. Thanks!
Old 06-27-11, 05:49 AM
bacardi
bacardi's Avatar
redliner8
they are very easy to replace. you are right, bushings are at the each end of the sway bar. question were did get the bushings?
Old 06-27-11, 12:59 PM
scyul
scyul's Avatar
Originally Posted by bacardi
redliner8
You can buy the bushings here:
http://www.tmengineering.net/suspens...n/make/gs.html
It's very easy to replace the bushings...
To replace the bushings, you must lift both sides (left and right) of the car to release tension on the swaybar. You can do the front, than the rear...
** Use axel stands! Never crawl under a vehicule supported only on hydraulic jacks!!!!! **
Remove 4 bolts on the supports... 2 on each side remove the old bushings... Grease the inside of the new bushings with the supplied grease. Use 2 screwdrivers or similar to open the urethane busing (pretty hard busings!!!) and slip the in position... re-install supports and bolts.
Done!
Old 06-27-11, 01:23 PM
scyul
scyul's Avatar
You can't slide them on. The bushings are splitted. You must open them up and slip them in position. No need to undo the swaybar ends... Just the supports.
Old 06-27-11, 04:37 PM
redliner8
redliner8's Avatar
great thanks, i was hoping you'd see this thread haha
Old 06-27-11, 06:45 PM
scyul
scyul's Avatar
Hope this info helps... Good luck!
Old 06-27-11, 07:04 PM
bacardi
bacardi's Avatar
scyul
yes it did, thanks. just ordered the sway bar bushing and steering rack bushing. didn't know you could still buy from them.
Old 06-27-11, 07:32 PM
scyul
scyul's Avatar
scyul
I didn't change the steering rack bushings... Let us know how hard it is to change them and if you notice any improvement.
Old 06-27-11, 08:52 PM
bacardi
bacardi's Avatar
will do. i hear they do make a difference. will see and let you know.
Old 06-29-11, 05:35 AM
bacardi
bacardi's Avatar
just got an e-mail, my order was shipped yesterday.
Old 08-08-11, 05:10 AM
redliner8
redliner8's Avatar
scyul, thanks for the recommendation on the bushings. I just installed them yesterday and i can feel the difference in cornering
Old 08-08-11, 07:03 AM
scyul
scyul's Avatar
Great! Thanks for letting me know!
Cheers!
MrHarris
Suspension and Brakes
13
03-22-15 02:05 PM
HammerDown
01-30-15 07:09 PM
Red Bully
09-06-08 04:42 PM
Scott1258
12-10-07 10:25 AM
Quick Reply: How to Install Daizen Sway Bar Bushings
