crankshaft bolt removal
Old 08-13-15, 03:14 PM
Bgw70
Bgw70's Avatar
Oops, yes a link would be nice...
See Post #14
Old 08-14-15, 09:52 AM
mandyfig
mandyfig's Avatar
Originally Posted by Bgw70
I have heard those are great tools, please have a look at a complete timing belt/water pump job using the crank holding SST, built at home.
It was made with parts from the hardware store and 15 min to assemble.
Steel rod
Pipe flange
Four bolts.
See all pics in post #2 and #19
https://www.clublexus.com/forums/sc4...bws-sc430.html
Thanks a lot!
I think I am ready to do this!
Old 08-14-15, 09:53 AM
mandyfig
mandyfig's Avatar
Here's what I watch before I go to sleep...
Old 08-15-15, 01:04 PM
empringham
empringham's Avatar
i would drastically recommend these tools over the torque air gun. tried three different ones on mine and had no luck.
Old 08-17-15, 05:16 AM
mandyfig
mandyfig's Avatar
I am with you. I was planning on buying a new compressor just for this job. Thanks for ramming this into my brain. Now I do not have a reason to procastinate. I need to visit the local auto store and rent the tool set.
Old 08-17-15, 06:08 PM
empringham
empringham's Avatar
ended up using the breaker bar and starting it. tried three times but it worked. would have been nice to have these, the proper tools. But there is always another way
Old 08-18-15, 07:35 AM
kjcole
kjcole's Avatar
Also nice to be able to torque the crankbolt properly upon reinstallation.
Old 08-19-15, 09:31 AM
mandyfig
mandyfig's Avatar
Very good point. You need this tool to hold the pulley.
Old 08-19-15, 09:32 AM
mandyfig
mandyfig's Avatar
Anybody listed the torque required for all the various bolts?
Old 08-19-15, 10:47 AM
Bgw70
Bgw70's Avatar
181 ft/lbs, crankshaft harmonic balancer pulley
Old 09-07-20, 07:28 PM
sorka
sorka's Avatar
Originally Posted by PLAYTYM
I see no need for one. Simply use a higher torque air gun on it and you'll have no issues.
And then how do you retorque it properly????
Old 09-10-20, 02:35 PM
Wilson2000
Wilson2000's Avatar
I'm with you on fabricating the tools. If one has the skills to tackle a TB job, then one has the skills for this kind of basic fabrication.
I read your 2015 post and saw you bumped the crank bolt loose with the starter. Did you try an air impact tool first? People have commented that the impact tool is risky, but I have not heard this before. I've done it on several TB jobs in the past without issue.
In one of your last photos, there was a good shot of the end of the crankshaft, with the pulley off. I noticed some rust on the crankshaft where the pulley mates. Did you polish this surface before replacing the pulley and did you use anti-seize to prevent future rust. Rust like this, but worse, caused major issues when removing my MR2 crankshaft pulley. I finally got it off, but had to spend an inordinate amount of time removing the rust. I liberally coated the mating surfaces with anti-seize based on my best judgement, but have never heard any other's opinions regarding this (done prior to internet forums like this one).
Old 09-11-20, 03:39 AM
Bgw70
Bgw70's Avatar
No, I don’t have air impact...
I don’t remember if I used anti seize...
bwils
11-21-22 05:04 PM
Spe3dfreak
IS - 1st Gen (2001-2005)
10-27-16 07:02 PM
johnboygs3
06-26-07 02:49 AM
bloodredSC
Performance & Maintenance
04-26-06 10:48 PM
BlazeGS3
GS - 1st Gen (1993-1997)
01-13-05 12:21 PM
Quick Reply: crankshaft bolt removal
